more fake eBay semis (OPA627=AD744) - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th April 2014, 11:07 PM   #1
laplace is offline laplace  Australia
Default more fake eBay semis (OPA627=AD744)
Die pictures here.
Open-Source F/Stop Timer
on flickr
Old 10th April 2014, 11:47 PM   #2
scott wurcer's Avatar
Originally Posted by laplace View Post
SW on the die - That's me! Pretty elaborate fake, amazing.
"Greetings from The Humungus! The Lord Humungus! The Warrior of the Wasteland! The Ayatollah of Rock and Rolla!" aka the Wizard of Wrestling.
Old 10th April 2014, 11:54 PM   #3
What, you did the layout for the AD744?
on flickr
Old 11th April 2014, 12:04 AM   #4
kevinkr's Avatar
Scott, I think the claim is that these are actual AD744 die packaged by someone as an OPA627. Is that possible?
Which detail in those shots is a laser trimmed resistor, I'm clueless.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 11th April 2014, 12:07 AM   #5
Must be strange seeing your own work repackaged in a counterfeit part.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 11th April 2014, 01:52 PM   #6
No, and I don't remember why the layout guy didn't add his/hers.
Old 11th April 2014, 01:56 PM   #7
Yes, they could buy die. The big green things with tabs are trims you can see the laser cut in a couple. The 1 drawn in the upper left square is the grade "bin 1". Far more common are parts erased and rebranded.
EDIT - In reviewing the pics carefully I think the author is mistaken. The bond to the comp pin was there by evidence of the acid etch pattern. This is far more likely a simple erase and rebrand. BTW the offset trims on the two parts are to different supplies and totally incompatible.
Old 11th April 2014, 05:53 PM   #8
PedroDaGr8's Avatar
Correct me if I am wrong Scott but for everyone else. These are the laser trimmed resistors.
In the first image, they are surrounded in green boxes with the laser cut shown by the yellow arrow. The one surrounded by the blue box looks like two resistors only one of which is laser cut. Maybe the blue one is a resistor divider, laser cut to the right ratio. By the way I love the clown face in the upper right corner
In the other IC I have highlighted the laser cut resistor with a green box once again and highlighted the laser cuts with yellow arrows.
Old 11th April 2014, 08:23 PM   #9
Right
Old 21st April 2014, 06:56 PM   #10
Follow up, That's not an OPA627 but a cheaper BB/TI part rebranded. I guess a case of double fakes.
Anyone tried these fake Diatones on ebay? fatbattery Full Range 11 18th December 2013 10:11 AM
Fake ICs off eBay johnr66 Chip Amps 0 12th January 2012 04:31 PM
iffp 240 on ebay, fake? 3GGG Pass Labs 25 6th December 2010 04:49 PM
possible fake lm3886T chips from ebay ;( linuxworks Chip Amps 17 6th December 2010 01:06 PM
Fake OPA627 chalky Solid State 14 15th May 2005 05:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
