| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Anyone knows where to obtain specifications for 2SC2461B and 2SA1051B please kindly let me know. I've checked Toshiba official site and nothing like these are available. Peter |
#2 |
http://harmsy.freeuk.com/nic.perciva...ransistor.html
I'm guessing TO-3... nice fT. Could make a hell of an inverter with 'em... Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
Thanks for the reply.I am glad that there is pages like these for us to check for specs.Unfortunately I did not find the "B" version of the 2SC2461.This is the version used in my Yamaha M2 and I suspect one of the 2461B is burned.I like to find out the specs so I might purchase replacement for it. Peter |
#4 |
Hi Peter
The B-version is not listed in my database either. It’s probably the same transistor but with even higher VCE then the A-version Looking here, Toshiba probably list replacement parts. Our Japanese friends could be of some help here. When looking at 2SC2461 (A,B) they are all replaced by 2SC5200. Datasheet 2SC5200. If the amp is worth it, I probably would replace all 2SC2461B’s from that one channel with 2SC5200. /Hugo |
#5 |
The 2SA1051 version A as well as version B are listed as obsolete in the 1993 Toshiba databook I have here. The 2SA1302 is recommended as replacement for both.
For the 2SA2461A/B the 2SC3281 is recommended as a replacement. The 2SA1302/2SC3281's are pretty standard audio power BJT's but also obsolete nowadays, however still available. Cheers |
#6 |
Thanks very much for the information,Netlist and Pjotr,now I think the Yamaha might have a next life to follow. I might replace all the output transistors afterall ,but, it's worthy the effort for the amp is a quality built unit. It's the time to dig the source for these devices. Thanks for the great help!
Peter |
| DSD 1751 data sheet | fmak | Digital Source | 0 | 25th June 2008 11:51 AM |
| Data Sheet for Extremis 6.4 | Tenson | Multi-Way | 5 | 24th November 2007 02:32 PM |
| looking for old data sheet | unclejed613 | Parts | 3 | 13th May 2007 06:35 PM |
| op amp/dac data sheet help | Smiffy | Parts | 11 | 13th December 2004 08:14 PM |
| Page generated in 0.08383 seconds (74.53% PHP - 25.47% MySQL) with 10 queries |
