Not sure where to get the right hardware - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th March 2014, 05:44 AM   #1
Question Not sure where to get the right hardware
Hi all,
I'm currently busy with building my own speaker system. It's a hobby of mine to listen to music, create it and so on. Without music my life would be a whole less fun :-)). Anyway, I've decided to build my own speakersystem and give it a design of myself. I've created a list of specs I want for sure:
- Bluetooth to control it via Phone
- Amplifier (ofcourse)
- 2x Exciter
- 1x Sub
- Batterypack which gives juice to all of the above
All this will be packed into a 40x40 cm cube which will carry a design similar to other thing inside our household. Now comes my difficulty...I really don't know anything about hardware. Yes I know I need the above, but where to get proper hardware is a bit confusing.
Do you guys know any place or company which provides an all-in-one solutions for the amplifier, bleutooth and batterypack? I really want it to be one board with all of it because space is limited.
Gerben
Old 7th March 2014, 10:46 AM   #2
DUG is offline DUG  Canada
Search "boombox" in diyaudio for that part...much has already been discussed...many great ideas.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 9th March 2014, 06:43 AM   #3
Thanks DUG. Looking into it right now
Old 21st March 2014, 05:33 AM   #4
LazyH is offline LazyH  United States
I know for bluetooth you can buy a little USB powered module pretty cheaply if you're willing to do a little soldering, that's what I've always done with m projects. I don't know about any all in one solutions though, you'd probably need higher voltage for the amplifier section so either having two batteries of differing voltage or, more practical, a single higher voltage battery with a cheap voltage regulator, 5 volts would be usb level, you can get those from radio shack for a dollar or two if i remember right. For amps, I like the tda style of amps, you can get them pretty cheaply on ebay, either the entire circuit premade or the chip itself so you can build the circuit as you need for your project, I like them because you can get them pretty small while still getting a nice amount of watts for your speakers.
Spatializer - hardware etc nathanjh13 Everything Else 0 5th July 2012 02:11 PM
Hardware help please Original Burnedfingers Tubes / Valves 4 19th December 2011 07:11 AM
need help with video hardware JL888 PC Based 11 23rd May 2010 12:43 PM
Finishing hardware loninappleton Full Range 20 30th October 2008 08:34 PM
Hardware?? lpd Tubes / Valves 5 6th March 2005 03:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
