PCB options and sources for LM3886 amp - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th February 2014, 12:19 PM   #1
Default PCB options and sources for LM3886 amp
Hi guys,
There would have to be a recent thread on this but I couldn't find it after a few searches.
I would like to build a 2ch lm3886 amp and was wondering who suppliers pcb's and their quality?
I have only located to sources:
Chipamp.com - I'm told these are well made and ready to go without modification?
eBay - there is two types both are not quite right and require addition parts added off the board and some if the tracks cut to fix.
Surely there must be others?
I'm located in Australia.
Old 15th February 2014, 12:01 AM   #2
There is this Altronics kit for a Silicon Chip project:
Altronics - K5130 50W Amplifier Module Stereo Kit
Old 15th February 2014, 12:50 AM   #3
hongrn is offline hongrn  United States
hongrn's Avatar
Go to eBay and search for "2pcs LM3886 diyAudio My Reference rev. C Amplifier PCB DIY New Board". Huge thread on this forum as well.
Old 16th February 2014, 01:13 PM   #4
Thanks guys - the My_Ref looks nice but I read the BOM is about $150US; which is a bit more than im looking plus I think I would like to start a bit simpler.
Is there a BOM for the chipamp.com stereo kit that includes the part numbers?
I just did an online order to see what it might cost and it came in at $100Aus from element14. Im pretty sure i selected the correct components, some of the resistors came in packs of 10 only which did bump it up a little. I would like to compare my selection against a list with part numbers to see if im on the wright track before i look to shop around.
I also found these boards which looked interesting:
Classic Lines LM3886 Dual Channel Amp PCB DIY | eBay
Ebay search:
Classic lines LM3886 dual-channel AMP PCB/DIY
Old 21st April 2014, 04:38 PM   #5
Has anyone built the classic lines kit? I have searched and found a few posts but nothing confirmed?
Voltage Sources & Current Sources rascal101 Everything Else 3 13th September 2012 01:56 PM
Great AMP PCB for sale~LM1875T & LM3886 slowgay Swap Meet 2 16th February 2009 01:24 PM
Teflon Washer&Solid PCB Board Sources gengis Everything Else 0 10th May 2005 03:37 AM
LM3886 Distortion Sources scott_jcp Chip Amps 1 6th April 2005 06:09 AM
Simplified LM3886 amp with PCB KostasTheGreat Chip Amps 39 21st November 2004 08:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
