Best way to clean a female RCA jack? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th February 2014, 08:32 PM   #1
JoeDJ is offline JoeDJ  United States
JoeDJ's Avatar
Default Best way to clean a female RCA jack?
Recently, the left channel on my my beloved NAD "C-350" amp intermittently started to get real low and distorted.
I should say that I have all my sources are fed into a source switch and that is connected to the CD input on the NAD as that input is where it defaults at every power up.
Long story short.........
I traced it to a bad RCA connection at the NAD's CD input .
Plunging it and unplugging it a few times cured it...... at least for now
I assume the jack had a bad connection due to its age, and possible lack of use before I got the amp.
My question is, what is the best way to clean the internal contact on a female RCA Jack?
Old 9th February 2014, 02:57 AM   #2
fas42 is offline fas42  Australia
Banned
Just a cotton bud and methylated spirits, or isopropyl alcohol and vigorous rubbing should get a sizeable chunk of gunk off. Repeat process with clean buds until no more gunk comes off.
If bud is too big, unravel some of the cotton, and wind that around the end of a toothpick, tightly. If the cotton comes off the end just dig it out with the toothpick.
Old 9th February 2014, 10:31 AM   #3
Mooly's Avatar
I would also suspect dries on the sockets... very common on all equipment and worth resoldering as a matter of course.
Old 9th February 2014, 10:36 AM   #4
Hi.
Sometimes, really rare in fact, metal tube at the and of female RCA socket could break.
I've seen it few times via servicing old amps. Then only way is to change a sockets.
Of course Yoy should check connection beetween socket and main board, because of pushing cable into socket, from time to time solder breaking on PCB.
Old 9th February 2014, 11:30 AM   #5
diyAudio Moderator Emeritus
jean-paul's Avatar
Dry joints on the PCB .... Lead free soldering ? Then check for sure. You need a magnifying glass. Often you see very thin cracks in the solder joints. Remove old solder with solder wick, resolder the joints. Ready.
It's only audio. Member of the non modular PCB design committee
Old 9th February 2014, 11:56 AM   #6
infinia is offline infinia  United States
infinia's Avatar
^thermal cycling produces solder cracks around pins at the PCB, I've seen this many times
esp on components fixed to chassis or heat sinks then to PCB.
mass produced integrated amps and plate amps with poor air flow are most susceptible.
reflow solder on all pins for whole connecter strip after tightening all mounting screws. This is a problem because completed PCB assy is screwed down after wave soldering connector putting stress on the pins.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 9th February 2014, 04:19 PM   #7
JoeDJ's Avatar
In my case it seems to have been just a "cleaning" issue and all is fine now but, I still want to clean the RCA jacks it further .
Thanks for the input.
BTW, one of the first things I did when first getting the amp was to remove the cover and inspect everything thoroughly and it all looks great.,
However I could nor see not the solder on the bottom of the CB of course..
Old 9th February 2014, 04:23 PM   #8
KatieandDad's Avatar
If it really needs a good clean then I use a cocktail stick wrapped with extremely fine P1800 wet and dry paper. But unless it is vintage I just replace the socket with a decent gold plated new one.
Old 9th February 2014, 04:45 PM   #9
Mooly's Avatar
Bit of kitchen paper soaked in iso and shoved up 'thole does the job I find
Wet and dry there goes any plating.
Old 9th February 2014, 05:54 PM   #10
JoeDJ's Avatar
one.
Actually, unless the male jack is also gold the different metals in contact with each other can possibly cause some corrosion . Just one gold contact does nothing good. .
This fact is often over looked.
http://en.wikipedia.org/wiki/Galvanic_corrosion.
I like your idea on how to clean it though as iso sometimes can't remove everything ..
Is there a 3.5mm female stereo jack that will detect when a cable is connected? hoffsta Parts 6 10th July 2013 11:14 AM
need help sourcing a quad female RCA jack rickcl Car Audio 14 2nd April 2013 09:57 PM
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 03:39 PM
Soldering Cardas Female RCA's? dantwomey Everything Else 2 16th December 2007 03:31 AM
Is it difficult to change female RCA plugs? Mrpong Car Audio 5 2nd August 2005 10:13 AM
Copyright 1999-2017 diyAudio
