Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Necessary with input capacitors on EQ?
Old 30th December 2013, 09:10 PM   #1
hansibull is offline hansibull  Norway
hansibull's Avatar
Default Necessary with input capacitors on EQ?
Hi!
I just got THIS NE5532 based EQ form Ebay today, and I immediately sat down and started soldering.
I discovered this kit had a pair of cheap 4.7uF input capacitors, but my amplifier already have a 1.0uF cap. is it necessary to have input caps on the EQ too?
Old 31st December 2013, 03:27 AM   #2
indianajo is offline indianajo  United States
indianajo's Avatar
Random sound sources put out a little DC voltage which can bang op amp outputs into the power supply rail if there is any gain at all. I've had trouble with tantalum input caps (popcorn noise from the store, 92% failure rate) and aluminum electrolytic caps are generally unreliable after 15-20 years, 5 for the really cheap ones. If you have room use a plastic film cap. If you don't have room I have been using 4.7 uf CPO ceramic caps with a 50 V rating. Yeah, they are non-linear, but the excess voltage rating straightens out the curve some; I really like them better than the tantalums with the popcorn noise. They are right next to the speaker in a power amp so I don't think the Aerovox gold ceramic caps I bought (which at >$5 each are not "cheap" caps) are not microphonic. If you are willing to put up with non-function of the EQ when the source device is at fault, you can remove them.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 31st December 2013, 10:08 AM   #3
hansibull's Avatar
I have a pair of expensive 3.3uF caps, but the problem is that these have very short leads, and is twice as big as the mounting holes on the PCB.
(same size and value as THESE)
I may try to fit in these, so I don't need to replace them after some time
Old 31st December 2013, 12:05 PM   #4
hansibull's Avatar
Do you have any recommendation for input capacitors for OP-amps?
How does electrolytic caps affect the sound versus mylar caps?
Old 3rd January 2014, 12:30 AM   #5
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
If you connect a magnetic cartridge to the input any biasing currant for the OP amp will be grounded through the low impedance coils in the pickup.
Necessary with input capacitors on EQ?Hide this!Advertise here!
Subwoofer input+filter+eq circuit zeus_threat Subwoofers 13 6th January 2013 08:13 PM
How come signal input capacitors are not on every amp? mbeards Tubes / Valves 11 25th July 2012 04:31 PM
eq input and output buffer emosms Instruments and Amps 3 8th July 2012 02:02 AM
marantz input capacitors Marcelinho Solid State 4 10th December 2008 04:23 PM
5R4WGY/A/B , input filter capacitors riccardo Tubes / Valves 12 26th July 2005 09:08 PM
Copyright ©1999-2017 diyAudio
