Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
JRC 4580 semiconductor
Old 29th December 2013, 02:09 AM   #1
Hayden is offline Hayden  Australia
Default JRC 4580 semiconductor
Does anyone know where I could get this IC from? as this one is faulty.
What is the J086G number? is it relevant?
Also are these all the same? what does the letter indicate?
4580
4580M
4580D
Any suggestions would be greatly appreciated as it may get my expensive amplifier going again
Old 29th December 2013, 02:59 AM   #2
ian33 is offline ian33
njm4580m
http://akizukidenshi.com/download/NJM4580.pdf
buy
http://octopart.com/partsearch#!?q=n...art=0&limit=10
Old 29th December 2013, 03:12 AM   #3
Thank you so much
I think I've worked out that the letter is the shape if the IC
So do you believe it is an M and not an E shape? as they look fairly similar on the datasheet or doesn't it matter? it just looks like it's the height that is different and the pins could be the same???
Old 29th December 2013, 03:28 AM   #4
eyoung is offline eyoung  United States
eyoung's Avatar
ck this out...
Package Dimensions | IC Package | Semiconductor Selection Guides | New Japan Radio(New JRC)
regards,E
"Lead me not into temptation...I can find it myself."
Old 29th December 2013, 03:56 AM   #5
Bibliophile is offline Bibliophile  Australia
Since you are in Australia, give Element 14 a try.
I think you'll find it's an SOIC8 package.
Manufacturer:TEXAS INSTRUMENTS Manufacturer Part No:RC4580ID. Order Code: 1857994 Trade Price: 1 - 24 $1.41
It's also known as NJM4580.
Last edited by Bibliophile; 29th December 2013 at 04:15 AM. Reason: Additional info
Old 29th December 2013, 10:48 AM   #6
Max Headroom is online now Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Just about any junked DVD player will have them....for free.
Dan.
Old 29th December 2013, 11:15 AM   #7
Mooly's Avatar
Pretty rare for an opamp to fail...
You could hardwire just about any dual opamp in its place as a test, 5532, 4558, TL072, TL082 etc
Old 29th December 2013, 12:46 PM   #8
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Agree.
Why do you think it's bad?
Old 31st December 2013, 02:12 PM   #9
VibroKing$ is offline VibroKing$  Italy
VibroKing$'s Avatar
Dan.
I agree now is the only way to have the components
Old 2nd January 2014, 02:52 AM   #10
Thanks guys so much!!
It's the only component that reacts to freezing spray.
If I put the hipass or lowpass filter on it has static crackling in the music but when I hit it direct with freeze spray the crackles go away, spraying other components have no effect. Also I did flux and re-solder it in case it was a dry joint but that didn't change anything.
This is what arrived today. The original chip has a dot to match up on the board to mark which way it goes so is it safe to match the line on the new chip with the mark on the board???
It says on the chip:
R4580I
29k
AS7DG4
Hope it works
JRC 4580 semiconductorHide this!Advertise here!
4580 JRC Add Line Out xtreamdev Chip Amps 11 4th August 2010 08:54 PM
Op-amp Replacement for 4580 (JRC) tk421storm Parts 17 5th December 2009 08:11 AM
JRC IC help moss99 Parts 6 8th September 2009 06:05 PM
wtb:4580 opams Ryssen Swap Meet 1 18th December 2008 07:51 PM
