| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
True, a 35A 1000V rectifier is about the size of a stamp and for a most reasonable price, but the question was how to avoid such, how to keep it all on the pcb.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#12 |
Every PCB's are mounted to the chassis with distance " nuts ". Rectifier you may solder from bottom side of PCB and screw it to the chassis through hole in PCB - it's easy and elegant.
| Low voltage rectifiers? | d1983 | Tubes / Valves | 6 | 18th July 2008 08:07 PM |
| voltage regulators | odysseybmx414 | Chip Amps | 23 | 2nd January 2006 08:35 PM |
| voltage regulators | GAK | Tubes / Valves | 12 | 25th January 2004 04:34 PM |
| Rectifiers, DC Supplies, Regulators and the like | kimwong | Parts | 0 | 9th December 2003 04:42 PM |
| voltage regulators | NAP 160 | Digital Source | 7 | 11th August 2002 09:14 PM |
