Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Low noise shunt referene?
Old 16th December 2013, 10:09 AM   #1
Tazzz is offline Tazzz
Default Low noise shunt referene?
The attached image is the noise density plot from the onsemi tl431 datasheet.
Does anybody know of a better or comparable shunt reference availble in a sot23 or similar package?
Old 16th December 2013, 11:00 AM   #2
davidsrsb is offline davidsrsb  Malaysia
That is about the same noise density as that of a 140k resistor, so I suspect a green LED or a zener would be much better
Old 16th December 2013, 11:03 AM   #3
audiostrat is offline audiostrat  Greece
audiostrat's Avatar
It also depends on how accurate you need the reference to be. I use LM329. It is quite low noise, and stable enough.
A led should be very good, but I can't say it would certainly be rock stable. So you might tell us how critical the application is.
Have a look at this thread too:
Zener vs Led as reference
Old 16th December 2013, 11:06 AM   #4
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The plot for the Sipex TL431 is marginally better. What's the application? When I need lower noise than the TI TL431 (considerably worse on paper than the OnSemi), I'll parallel them and/or filter the output.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th December 2013, 11:29 AM   #5
gentlevoice is online now gentlevoice  Denmark
Hi - I would also suggest a LED (green, orange, yellow) combined with a CCS and a good capacitor(s) for decoupling. Yet i don't know you application ...
If LEDs are a possibility for you you might find Christer's measurements interesting (attachment)
"... It is always possible to be friendly ..." HH the Dalai Lama.
Low noise shunt referene?Hide this!Advertise here!
Low noise, low microphony, low hum valves MarcelvdG Tubes / Valves 38 28th January 2013 08:42 PM
Erno Borbely All FET low-noise super shunt regulator lujunweilu Power Supplies 2 8th December 2010 04:02 PM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Help with dual PS noise shunt? cuibono Power Supplies 15 22nd March 2008 08:00 PM
Help with Shunt Regulation and Noise dsavitsk Tubes / Valves 30 24th December 2007 06:11 PM
