Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Lemo connector phono cable
Old 13th November 2013, 02:14 PM   #1
hessec is offline hessec
Default Lemo connector phono cable
Hi all, I'm new here and have a cable question.... I've made quite a few in my day but this one has me a little bit baffled.
On my Tonearm I purchased an option for a balanced connector. i.e. xlr etc.. On this particular termination block the manufacturer is using 3 Pin Lemo (push pull) connectors on the arm end and XLR termination at the phono stage end.
In speaking to the manufacturer a while back, he told me they float the ground on one end of the cable. Well, turns out that happens to be the Male lemo end and not the XLR end. So, only 2 of the 3 pins are wired on the cable at source- I do not know what the circumstances are inside the tonearm termination block.
Long story short, I now need an rca cable for my TT. If the Lemo end is not wired with the 3rd wire couldn't I just cut the XLR off the other end and solder on an RCA? only connecting the same 2 wires? It would seem that it is essentially already an rca with an alternative connector as the source end does not have the ground wire connected. Or I could wire the hot to the pin of the RCA and the neutral and ground wire to the barrell of the RCA and this might give me some shielding?
Only other option is to send back to manufacturer for a tonearm rewire and purchase a new RCA cable and that would be Big $$$. It seems like my fix would work but I'm not dealing with throwaway wires and would prefer to not make a mistake. The wire will be a pain in the butt to solder as it is of such small gauge.
Thanks, Chris
Old 12th May 2014, 05:46 AM   #2
daimen lee is offline daimen lee
Smile Hello Chris
we are the manufacturer for compatible lemo connectors with cables .
深圳市得著科技有限公司,国内连接器行业看领军企业之 ,圆形精密连接器,防水连接器,推*自锁连接器,医疗连 悠,工业连接器,汽车连接器,航空连接器,LEMO雷莫连接 ,快速连接器,气路连接器 , my email :sale4@touch-sz.com
you can add my skype:touch.sale4
Thanks.
Old 13th May 2014, 12:25 PM   #3
janegood is offline janegood  South Africa
Thanks, Chris
If you don't want the XLR (which would have the cable screen connected to pin 1), the alternative to the RCA with screen and cold connected to the RCA shell, is to take the screen to the earth terminal on the phono pre-amp, together with the arm earth wire.
Lemo connector phono cableHide this!Advertise here!
Push pull connector compatible with LEMO sreada Vendor's Bazaar 2 14th April 2014 07:20 AM
Internal Tone Arm Cable between Cartridge and Connector for the outside Tonarm Cable tiefbassuebertr Analogue Source 3 24th June 2012 08:51 PM
multipin power cable connector chokesrule Parts 4 6th December 2010 09:43 PM
PS cable and connector rif Parts 3 1st February 2003 04:35 PM
