yamaha cr600 replacement bulbs
I'd had spent many hrs researching these... I recomend replacing 1 bulb at a time, so not to screw up wires and ALL the bulbs need to be replaced, because some of the bulbs are hooked in series and draw diffenent currents. If you screw up the wiring, it can burn out the pwr supply for the bulbs. It's time consuming and not much fun, till your done....
