Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th December 2003, 03:01 AM   #1
Default crossover component help
Well I am fixing to start on my very first project, the Audax home theater set. The problem I am haveing is finding a few of the xover components. Mostly the Inductors, now my question is what will happen if I use and inductor that is rated at say 1.8mH at 0.27ohms instead of the one in the diagram that calls for 1.8mH at 0.43 ohms? What acoustic changes will that make to the xover network design? Now my next question is about resistors. What is the difference between using a 8ohm at 10watt or a 8ohm at 12watt? Can I use a 12watt instead of the called for 10watt? And could you please give me some links to buy some of this hard to find stuff. I have tried Partsexpress, Madisound, and Zalytron.
What's a woofer?
Old 20th December 2003, 11:12 AM   #2
"Mostly the Inductors, now my question is what will happen if I use and inductor that is rated at say 1.8mH at 0.27ohms instead of the one in the diagram that calls for 1.8mH at 0.43 ohms? What acoustic changes will that make to the xover network
design?"
Nothing at all in my opinion, for inductors resistance values below
1R you can safely use up to 0.5 the R value and to 1.5 the R value.
Sometimes inductors have highish R values > 1 you shouldn't change these.
"Now my next question is about resistors. What is the difference between using a 8ohm at 10watt or a 8ohm at 12watt?
Can I use a 12watt instead of the called for 10watt?"
The 12 watt can take more power, fine to use instead of 10 watt.
sreten.
Old 20th December 2003, 12:12 PM   #3
Originally posted by sreten
[BNothing at all in my opinion, for inductors resistance values below
sreten. [/B]
Please clarify, I think the simple answer to my question is it would be ok, but I am not really sure what you mean by "1R and 0.5 the R values". I am extremely new at this and am basicly taking a crash course in electronics. Thank you for your help.
What's a woofer?
Old 20th December 2003, 12:19 PM   #4
I think I understand, what you mean is I can use up to 1/2 the required resistance and upto 1 1/2 x the required resistance. so say I need a Inductor that is 1.2mH @ 0.34ohms I can use one that is 1.2mH @ 0.17ohms or one that is 1.2mH @ 0.51ohms. Is this correct?
Thanks.
Daryl
What's a woofer?
Old 20th December 2003, 07:55 PM   #5
Yes thats basically it. I should have said :
For inductor resistance values of less than 1 ohm you
I forgot to mention :
make sure you are not substituting a ferrite cored inductor
for an air cored inductor, air cored inductors have higher
R values than the ferrite cored equivalents.
You should not change types.
sreten.
Old 20th December 2003, 11:12 PM   #6
Thank you for your help. Will make my life a bit easier for my first DIY project.
Daryl
What's a woofer?
Zaph ZD5: Crossover Component Checklist soundengine355 Multi-Way 4 6th August 2008 02:09 AM
Possible flaky crossover component greenie512 Multi-Way 0 27th July 2008 02:17 AM
crossover component Jerry Calà Multi-Way 4 9th February 2008 07:56 PM
crossover component replacements paper Full Range 3 24th June 2006 06:23 PM
crossover component positions michael Multi-Way 2 10th December 2003 07:59 AM
Page generated in 0.09026 seconds (76.07% PHP - 23.93% MySQL) with 10 queries
