Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th December 2003, 10:50 AM   #1
Magura is offline Magura  Denmark
Magura's Avatar
Question Copper heat spreaders
Anyone got experience with copper heat spreaders?
How big and how thick for the respective heat transfer?
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 19th December 2003, 12:25 PM   #2
jackinnj's Avatar
both Wakefield and AavidThermalloy have "white papers" on their websites -- some of the articles are pretty academic. There is a very good explanatory paper on the On-Semi webiste -- they have all their application notes chronologically listed -- look for Ap Note 1570 on Thermal Management.
Old 19th December 2003, 01:47 PM   #3
diyAudio Moderator Emeritus
roddyama's Avatar
Here are a couple of threads (one with photos) that talk about the subject. There are more that I haven't been able to find.
http://diyaudio.com/forums/showthrea...5&pagenumber=2
http://diyaudio.com/forums/showthrea...307&highlight=
In one thread that someone I havn't found yet, someone actually has measurements with and without the spreader.
Rodd Yamashita
Old 24th December 2003, 12:46 PM   #4
sully is offline sully  United States
Account Disabled
The heat spreader is used to spread the heat to a wider area.
Copper has about twice the thermal conductivity of aluminum, so give less thermal drop closer to the transistor die.
By making the copper thicker, the actual thermal grease area that is used to transport heat is larger. This is where the most benefit occurs, by making the heat path wider where the electrical insulation is.
If anybody would like to know more about the 45 degree heat path thermal modelling, I'll be back on the 5th of Jan.
Happy holidays...Happy new year..
Cheers, John
Copper going away at 350° ? Bernhard Parts 8 12th May 2008 07:28 PM
Copper patinization? JoshK Tubes / Valves 6 11th April 2008 04:51 PM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
copper board badgers Parts 2 28th February 2005 08:20 PM
Use of heat spreaders in sealed sub stuffing Beggar Multi-Way 3 15th July 2003 06:13 PM
Page generated in 0.06806 seconds (80.86% PHP - 19.14% MySQL) with 10 queries
