Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th December 2003, 07:22 AM   #1
Andypairo's Avatar
Default W054 Zener diode, what is it?
While fixing an old Luxman tube pre-amp (CL-32) I noticed that the turn-on delay relay was not working (the relay was going immediately on/off with the power supply), so I checked the semiconductors on the little board and found 2 bjts and this zener faulty.
The zener was marked W054 but, finding no info about it, I guessed it could be a 5.4V zener (I discarded the 54V idea because the bjts are rated 35V).
Putting a 5.6V zener at its place made things work again, but I wonder if I used the right component.
Can anyone help me?
Cheers
Andrea
Old 25th December 2003, 03:40 AM   #2
KCC is offline KCC  Canada
I have a similar situation here.While repairing a Yamaha M2 power amp I encountered a bad zener diode that has a "10" marking on it. I have also seen other Japanese zeners with "3" or "5" marking on them.And that's all. I assumed that they mean 3 volts ,5 volts and 10 volts accordingly. The 10 volts zener is termed as HZ6CIL in the service manual.I've checked many places and no body knows what that is. I replaced that with a 10 volts zener 1N4740 and seemed to be working so far.
Peter
Old 25th December 2003, 03:45 AM   #3
Peter
Old 25th December 2003, 09:52 AM   #4
Netlist is offline Netlist  Belgium
Netlist's Avatar
Peter,
This is probably your diode: http://www.renesas.com/avs/resource/...08118_hz_l.pdf
Andrea,
W054? Can’t find it
/Hugo
Old 25th December 2003, 04:20 PM   #5
Netlist,
Thanks for the pdf. I've finally come to know the specs of this zener.Appreciated.
Peter
Old 25th December 2003, 04:31 PM   #6
Netlist's Avatar
Originally posted by KCC
Appreciated.
/Hugo - only one click away...
Zener Diode Question Captn Dave Tubes / Valves 12 17th June 2009 08:16 AM
zener diode question mike49504 Car Audio 2 2nd September 2007 06:17 AM
Quicksilver zener diode mod newears Tubes / Valves 19 31st December 2004 10:41 PM
regulated PS - with Zener diode ErikdeBest Tubes / Valves 11 30th June 2004 09:48 AM
Zener diode indentification! bbakota2000 Parts 2 22nd March 2004 11:55 PM
Page generated in 0.08355 seconds (78.37% PHP - 21.63% MySQL) with 10 queries
