Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
BASIC CAPACITOR QUESTION
Old 10th October 2013, 02:38 AM   #1
FNQ is offline FNQ  Australia
Default BASIC CAPACITOR QUESTION
Hey guys... 2 Questions... In old Yamaha organ power supply a 35v 2.2uf Tant is specified. This model organ is well known to need replacement of this particular cap. I'm not a techie so I can't say what this Tant's job is but I do have full factory schematics I can scan a page of if needed. So query is should I replace the 35v with a higher voltage Tant or what?
Secondly when I buy more 'lytics for same organ-instrument is choc FULL of 'lytic cap's btw..if retailer out of regular Cap's he told me he has some of the needed values in Non-Pola version and will be OK if installed instead of "regular electrolytic" ...Is this correct?
Will appreciate your input..Cheers.
Old 10th October 2013, 08:04 AM   #2
dimashek is offline dimashek  Germany
1) Higher voltage is ok. Depending on the place of use, it could also be replaced with e-lytic
2) generally: e-lytic in Signal path can be replaced with non-polar. Elytics in PSU /decoupling don't need to.
Old 10th October 2013, 10:49 AM   #3
ticktock is offline ticktock  Scotland
ticktock's Avatar
If reliabilty is a typical issue, higher voltage is preferable. Tantalums usually
don't suffer from aging though (if voltage is choosen sufficiently).
Again, higher voltage is better if there's enough space for the physical size.
Regarding bipolars, you need to know if the cap is in the signal path or just
filtering/buffering power. The schematic would help a lot. If signal path BP is
fine, if power supply it's not. Remember regular lytics aren't hard to get at all.
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 12th October 2013, 01:14 PM   #4
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
Bipolar capacitors are far less reliable and sacrifice ESR and reliability for the bipolar feature. I would not use them in an audio path at all.
Old 12th October 2013, 01:20 PM   #5
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I don't think he is after better performance, just a reliable repair.
Tants in the signal path are a NO-NO in terms of audio quality but if you are just repairing like for like then the higher voltage devices are OK.
Tants DO NOT like voltage reversal. They tend to explode rather dramatically.
You can replace a tant with an electrolytic but their lifespan is generally shorter and they are usually bigger.
BASIC CAPACITOR QUESTIONHide this!Advertise here!
How to measure capacitor with a basic digital multimeter? KimmoSWM Parts 17 23rd January 2014 11:44 AM
Very basic question... andalarct Full Range 17 17th May 2013 01:05 AM
Basic Question jrwalsh33 Instruments and Amps 7 11th October 2012 01:39 AM
really basic question cuallito Tubes / Valves 6 15th April 2004 09:25 PM
really basic question MbayAQ Digital Source 3 7th January 2003 01:57 PM
