Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
AD797 overheating (ANZ flavor)
Old 6th October 2013, 09:19 PM   #1
michouthefirst is offline michouthefirst  Canada
Default AD797 overheating (ANZ flavor)
I am testing an AD797ANZ in a filter circuit and I noticed that on quiescent state the amp is drawing around 60mA from the PSU (+/- 15V). This makes it heat because it has to dissipate 2W.
I built a simple circuit of inverting amp (2 10-K resistors, 0V input, 0V output) and it still does the same.
I have a bunch of 10 which I bought off eBay. They all do that.
Is this normal?
Old 6th October 2013, 09:42 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
This is not normal. I would tell your supplier that they are faulty and ask for a refund. Always buy from a trusted supplier like Mouser, Farnell, RS Components and the like.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 6th October 2013, 09:46 PM   #3
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
That chip is very sensitive to layout and PS bypassing issues which can make it prone to HF oscillation, and it's not really the best choice for unity gain operation. I personally don't like to buy parts from unknown/untrusted sources, lots of fake components out there. Having said all that, what kind of filter were you trying to build and what do you want it to do? A schematic would be helpful.
Mike
Old 6th October 2013, 09:50 PM   #4
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Open door: how is the power supply decoupling arrangement ? As posted by other members AD797 is very sensitive and I have seen them oscillating more than once.
It's only audio. Member of the non modular PCB design committee
Old 6th October 2013, 10:27 PM   #5
The power supply is a lab power supply (Agilent). I think the parts are probably fake. This happened to me a couple of times. The sellers had a very positive feedback.
I will try decoupling the power supply and see how it goes.
For the filter, it was in fact a tone control circuit. I am new at DIY audio and still at the learning stage.
Thanks all for your answers, really appreciated.
Old 7th October 2013, 05:42 AM   #6
jean-paul's Avatar
Decoupling the supply pins straight at the AD797 would be wiser.
Old 8th October 2013, 12:57 PM   #7
macboy is offline macboy  Canada
Absolutely necessary, actually.
It seems that the OP didn't bother to even look at the AD797 datasheet other than to drool over the low noise and distortion figures. It spells out some very specific recommendations for stability, among them are some strict decoupling requirements.
Old 8th October 2013, 02:41 PM   #8
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Please post a schematic. This is groping around in the dark. There are many ways this can happen. For instance, is the 60mA from both rauils or only from one rail? How hot does it reaaly get, just hot to the touch or too hot to keep your finger on it?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 8th October 2013, 02:43 PM   #9
jan.didden's Avatar
This is too harsh - we don't even know what the cause is! You judge without having a clue.
Jan
Old 9th October 2013, 01:20 AM   #10
What are you suggestions for capacitors values for effective decoupling?
I tried 10uF with 100nf straight at the pins, same result. Please bear with me as I am a noob.
AD797 overheating (ANZ flavor)Hide this!Advertise here!
ad797 plus buf634 nonsqtr Analog Line Level 5 11th August 2013 01:26 PM
AD797 guts aparatusonitus Solid State 3 21st March 2008 05:02 PM
Active Crossovers, my flavor of the month alexmoose Solid State 34 2nd October 2007 06:55 AM
Bipole + Dipole with lineaum flavor! badman Multi-Way 2 18th September 2006 04:43 PM
Ad797 audioPT Parts 12 31st October 2003 09:07 PM
