Best 100uF cap for 15 volt rail - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th September 2013, 07:28 PM   #1
xymox1 is offline xymox1  United States
xymox1's Avatar
Default Best 100uF cap for 15 volt rail
Its been a while since I tried to figure out what the best sounding 100uF cap for a 15 V rail was. Im not specific on value, it could be smaller, it can be bigger, but size is a factor. A big polyproplene is not gonna fit.
Its for a power supply rail for a transistor gain stage for a DAC.
Also if price was not important are there any crazy caps that are small that will do this.
Old 24th September 2013, 10:23 PM   #2
JonSnell Electronic's Avatar
100uF Electrolytic at 16Volts with a 100nF poly in parallel is fine. Cost will be around $3 US. If you pay any more you will have been seen off!
Support for Fender, Marshall and all Valve Equipment including Audio Innovations, Quad and Leak. www.jonsnell.co.uk
Old 24th September 2013, 11:18 PM   #3
Reality first!
ClaveFremen's Avatar
I suggest you to use a 50/63V or higher rated cap, it will usually sound better than a 25V one.
My favourite, a safe and not too costly choice, is Elna Silmic II (black version, not the brown ROHS one).
Other good ones are Nichicon FG, FW, Elna RJH.
Avoid low ESR caps (apart RJHs).
Disclaimer
My suggestions are based on uncontrolled subjective evaluations, please avoid any sterile controversy.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 25th September 2013, 09:23 AM   #4
xymox1's Avatar
Interesting. Yes i want to try and avoid doing any bypassing with a second cap. The reason is I want my higs to have the same sonic attributes as my lows. Thats of course IMHO.. So I would prefer to use one cap. Yes i know a cap might sound different at different freqs.
Interesting to avoid low ESR. Normally a low ESR is of course a good thing. It would be with a film cap. Why is this ?
Old 25th September 2013, 10:07 AM   #5
Reality first!
I usually avoid too bypassing PS caps, IMHO, they often harm more than what they fix...
But if a bypass is necessary I consider an X7R ceramic the less intrusive (soundwise).
Low ESR caps I've tried are unbalanced or harsh or both, unique exception Elna RHJ, particularly in voltage gain stages.
Low ESR caps, though, can be preferrable where current is required (es. transimpedance amps), in such case I use RJHs.
Dario
Old 25th September 2013, 10:45 AM   #6
just another
wintermute's Avatar
I was going to suggest some organic polymer capacitors until I had a closer look at the datasheet. I've not used them, but had been considering it. Their rated ripple current is at 100Khz and reduces dramatically at lower frequency.
For example the panasonic SEP series you need to muliply the rated ripple current by 0.05 to get the ripple rating at 120 Hz... So much for that idea!!
Tony.
Any intelligence I may appear to have is purely artificial!
planet10 needs your help: Let's help Ruth and Dave
Old 25th September 2013, 10:28 PM   #7
xymox1's Avatar
Yea ive seen thoise cap too. Ive never listed to them It would be interesting to listen to them.
Ive used silver case wet tantalums in some places for digital and video stuff. Like a DAC digital voltage rails. The hyper low ESR and super wide freq range of a wet tant seems to work well on digital stuff. BUT these caps are stupid expensive and hard to get. They are weird for audio tho. They smear detail.
I tell ya tho. This signal on a unipolar DAC is just stunningly critical. As the ground point that is synthesized as the zero point for the differential outputs from the DAC's it turns out to be amazingly critical. This is most apparent when playing back SACD DSD.
Old 26th September 2013, 03:01 AM   #8
just another
wintermute's Avatar
If the supply is regulated with very low ripple then the organic polymers would be worth a try. They seem to offer the advantages of electrolytics in size terms, and the advantages of ceramics or film caps in the high frequency range.
The downside is that they don't seem to handle ripple at the frequency that a non-regulated linear supply will have.
Tony.
Solen 100uF 630V cap mmmalmberg Swap Meet 10 1st July 2013 03:10 AM
140 volt op-amp rail to rail nigelwright7557 Solid State 2 13th December 2012 02:00 AM
Source for 100uf motor run cap. audiobliss Tubes / Valves 3 31st July 2008 03:15 AM
Filter Cap Directly from Rail to Rail, excluding Center Tap Workhorse Power Supplies 8 29th August 2007 12:33 PM
Rail voltages from 15-0-15 volt transformer Bama Slamma Power Supplies 3 26th November 2006 10:27 AM
Copyright 1999-2017 diyAudio
