Non-Conventional Audio Parts and Sources - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th September 2013, 07:31 PM   #1
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Default Non-Conventional Audio Parts and Sources
I have been wanting to start this thread for a while now. Today is as good a day as any.
There is a ton of ingenuity out there in the world. I hope you can share some of it here. Please share with us items you have used in your audio projects that are not typlically used for audio equiment.
Pictures are welcome!
For example, one of my favorite is the Ikea wood bowl sphere speakers.
BLANDA MATT Serving bowl - 11 " - IKEA
Again from Ikea, the Lack table for an audio rack. I wrote up an article for EnjoytheSound.com. It's in the DIY section. It appeared last year.
LACK Side table - high gloss/pink, 21 5/8x21 5/8 " - IKEA
I have used a number 13" crochet needle as a tone arm and a smaller one for the pivot point on a unipivot tonearm. The plinth is a chopping block from Bed, Bath and Beyond. The counter weight is a plumb weight from Home Depot.
Table_0 - My Photo Gallery
If you have any unconventional audio part ideas, please share them here!
I build, therefore I am.
Old 28th September 2013, 01:31 AM   #2
Love this thread idea.
A few years ago I created a plinth for my Thorens TD124 by creating a sandwich from a pair of Ikea honeycombe-inside tables.
Here's the thread:
Re: new Thorens TD124 owner - albertoderoma - Vintage Asylum
Alberto
Old 30th September 2013, 05:34 AM   #3
Feet of my amp are made from gas filter columns that contained solid chemicls. The knurled Al end cap and the transparent PP pipe had to be extended. So a C-PVC plumbing pipe was used.
Old 22nd January 2014, 04:05 PM   #4
vdi_nenna's Avatar
Default Selector and volume switch extender
Hardware stores like Home Depot have threaded rod extenders. They also have aluminum and steel rods without threading. With a drill press and vise or drill and pliers, you can drill out the threads in the extenders and join the the selector and volume control shafts to extend them to the front of a chassis. Only catch is you will need set screws. With a tapping kit it's easy. Home Depot has set screws of all sizes. If no tapping kit is available, just try self-tapping screws. Run it through and then cut off the screw's cutting tip
The "L" brackets are just steel brackets drilled out to fit the controls threading.
Is it worth it? Maybe if you are trying to squeeze out as much performance as possible.
Enjoy,
Vince
Last edited by vdi_nenna; 22nd January 2014 at 04:27 PM. Reason: More info and grammar
Old 26th February 2014, 09:39 PM   #5
jdg123 is offline jdg123  United States
jdg123's Avatar
Default reuse DVD player case
It is not the little things that stop you from building, it's the expensive ones!
Casework has been known to stop a few otherwise avid solder slingers. For a preamp I curb picked a DVD player, gutted it and threw away the plastic front replacing it with a sheet of plastic with a photo stuck to the back side. Looking for some WAF? Let her pick the photo ;-)
The amp underneath was built from aluminium from the scrap yard which has huge boxes full of CPU coolers and larger pieces of angle aluminium and aluminium brackets!
Old 27th February 2014, 03:19 AM   #6
Carlp is offline Carlp  United States
jdg123, cool idea. I've saved a few chassis from expired electronics but was trying to figure out how to make the front useable. You may just have answered my question. And yes, I too am one who often hesitates on solder-slinging projects b/c of the case challenge.
Old 27th February 2014, 03:20 AM   #7
Don't know if it's relevant, but on another thread I just learned about this source:
Manufacturer of Precision Components | Spur Gears | Sprockets | Timing Belts | Timing Pulleys | Miniature Bearings | Shafts | WM BERG Engineered Mechanical Components
Old 27th February 2014, 02:39 PM   #8
jdg123's Avatar
Default what's the deal :0
Carlp,
Gosh yes there are so many cool gizmos I'd like to incorporate into some pieces I dream out while I take my morning coffee. Then I wake up.
I am dealt time and no money right now so my ideas are focused that way, toward what's free or nearly so. Solving the ugly nose problem on the ubiquitous DVD player carcass was a simple bit of inspiration, I had plexi and I have a lot of photographs. I hope this solution speaks to someone out there
Now I am thinking about casework that can shed a lot of heat for a big class A amp. I wonder if they ever scrap power transformer cases? I think I'll put in a call to my electric co-op
Cheers!
parts sources muscmp Parts 12 11th February 2011 11:45 PM
Inrush current sources in a conventional supply rtarbell Parts 4 20th July 2008 09:08 AM
Help needed - DIY parts sources in UK?? mubeen1983 Chip Amps 37 18th July 2008 12:54 AM
Sources for parts? preiter Chip Amps 22 25th October 2007 03:40 AM
Australian speaker parts sources ooty_boy Full Range 0 10th November 2005 04:47 PM
Copyright 1999-2017 diyAudio
