Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Coil replacement  TO COIL 330UH IN THE pathway regulator 7809 ?
Old 15th September 2013, 10:35 AM   #1
dazzz is offline dazzz  Israel
Default Coil replacement TO COIL 330UH IN THE pathway regulator 7809 ?
I need help on the part chosen for the SMPS mode of Danon 2900
One of the components I replaced this coil L909
Its value 4.7UH
His model is LHL08TB4R7M
Inductance- 4.7UH
Current Rating-
3A
DC Resistance- 0.025
Frequency - Self Resonan- 30MHZ
Q @ Freq - 40 @ 7.96MHz
I bought this coil PANASONIC - ELC-10D Series 330UH
nductance-330UH
DC Resistance Max-0.32ohm
RMS Current (Irms) - 900mA
DC CURRENT RATING-0.9A
Test Frequency
-10KHZ
Can I use a coil that I bought
I worry only because the current value ?
Old 15th September 2013, 11:17 AM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
From the small bit of the circuit that you have shown, it appears to be too low a current. The voltage there is DC so the coil is only there to reduce HF noise. Be careful of its DC resistance though as there could be up to 3A flowing, 1A each through the 3 x regulators that can be seen.
Personally I would get a coil that can handle at least 3A, not 0.9A, as the regulators have heatsinks they might be passing more than 0.9A in total.
Old 15th September 2013, 11:26 AM   #3
This is what I thought to
Old 15th September 2013, 11:49 AM   #4
FoMoCo is offline FoMoCo  United States
There could be up to 3A flowing, but most likely not. You can always measure the current flowing. If it's under, say, 500mA, go for it. Or you can play it safe and get an inductor with a higher current rating. (My personal choice.) The inductance value would not be critical.
Account Deletion Requested: 1/26/2014
Old 15th September 2013, 12:17 PM   #5
My problem is to find coil 330UH
That the diameter is not too large
( In the Area I replaced the coil dnot have much room )
3 amps I've seen in FARRNEL
Starting diameter 25 mm
Old 15th September 2013, 12:35 PM   #6
It's probably not doing much anyway, try a shorting link in place of the inductor.
Old 15th September 2013, 01:08 PM   #7
I have a reason I replaced the coil
I do a comprehensive project on power supply
The DENON DVD 2900
And increasing the value of this coil give me better nois filtering to reg 7809
7909
9 volt
If I replace the coil in this with shorting link I did not do anything
Old 15th September 2013, 01:14 PM   #8
True, but you can't find a coil to fit.
You could try an axial coil and mount it vertically.
Old 15th September 2013, 01:20 PM   #9
This one might fit.
Buy Leaded Inductors Inductor radial ELC09D 4.7uH Panasonic ELC09D4R7F online from RS for next day delivery.
Old 15th September 2013, 01:24 PM   #10
I might have a solution
Buy Coil 330UH 4.5A
FROM FARNELL
MURATA POWER SOLUTIONS
INDUCTOR, 330UH, 4.5A
And mount it in the bottom of the SMPS
What do you think ?
Coil replacement  TO COIL 330UH IN THE pathway regulator 7809 ?Hide this!Advertise here!
Ruark Sabre voice coil replacement Icurus Multi-Way 7 24th July 2013 08:13 PM
Found perfect relay replacement - but coil resistance is off. Which one is better? Coconuts 500 Parts 5 1st September 2012 06:38 AM
Audax TW034X0 Replacement Voice Coil Polarity swantzilla Parts 5 21st May 2011 11:06 PM
Centre tapped coil with in a coil - inductance? peskywinnets Solid State 1 31st March 2010 06:13 PM
Advice on DIY voice coil replacement Mayank Subwoofers 13 31st May 2009 07:48 PM
Copyright ©1999-2017 diyAudio
