I used information from a 1995 WIMA catalog I have. The case size and color are two clues. MKP2 parts will be a bit larger and therefore have higher inductance which translates into worse decoupling at high frequencies. With the parts being pin-in-hole, there is some distance between the capacitors and op amps so that printed circuit board trace inductance may dominate. In the end it probably isn't worth changing the MKS2 parts for MKP2 in this application.
Probably Bill is right with MKS2. There are some MKP2 or MKP3 I have im my spare box
with similar lead spacing, but more height. If capacitance isn't critical, it's even more
likely to find an MKP or even FKP3 (film-foil) to fit. Is this 7.5 mm lead spacing (RM7.5)?
The green Wimas are certainly already FKP2s, 1000 pF = 1 nF. Current ones are red
similar to MKP and MKS etc..
Search for the Wima parts catalogue or see wima.com . In many applications there are
sonic advantages for film-foil poly caps, even when they're lower capacitance.
There's an 15 nF ( = 0.015 µF ) FKP3 with 7.5 mm spacing ( # FKP3C021502C00),
which are fine for bypassing. Don't know if the specific value is critical. If the your
current 100 nF caps are indeed MKS2, then MKP4s would be a worthwhile upgrade.
0,10 µF - 63 V - MKP4D031002D00
0,10 µF - 160 V - MKP4F031002D00
0,15 µF - 63 V - MKP4D031502E00
0,15 µF - 160 V - MKP4F031502E00
all with 7.5 mm spacing.
FKP3 with 10 mm:
0.033 µF - 63 V - FKP3C023303D00
0.033 µF - 100 V - FKP3D023303G00
0.033 µF - 160 V - FKP3F023304D00 (15 mm)
MKP4 with 15 mm:
0,47 µF - 63 V - MKP4D034704D00
0,47 µF - 160 V - MKP4F034704D00
If there are caps with 15 mm lead spacing I'd prefer these:
0.10 µF - FKP3C031004C00
0.15 µF - FKP3C031504F00
0.22 µF - FKP3C032204J00
0.22 µF - FKP1G022204D00
0.33 µF - FKP1G023304F00
For the Wima MKP4, FKP4 0.47 µF come with at least 27.5 mm (FKP4J024704J00).
Suspectively the current ones are smaller in physical size. I'd leave them and just
bypass them with a small value FKP on the underside.
As the green Wimas are already FKP2s - I forgot to say, leave them. MKPs are
better than MKS caps, FKPs are better than MKPs.
BTW, "VR101" and "VR201 on the PCB are empty. Is there a bigger model with the
same PCB? If so I'd get the service manual and consider to retrofit the regulators.
FKP3 with 10 mm:
MKP4 with 15 mm:
VR is variable resistor for Offset Adjustment, as marked.BTW, "VR101" and "VR201 on the PCB are empty. Is there a bigger model with the
- Design & Build
- Parts
- Identify some Wima caps?
