Stupid Question- How To Use Ball Bearings? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th December 2003, 05:00 PM   #31
lgreen is offline lgreen  United States
lgreen's Avatar
Default At the Risk of Interrupting
Hey, that's all great advice, thanks everyone.
Actually, now might be a good time to mention that the shaft is going to both rotate and pivot vertically. So its going to be mounted on a hinge of some sort. So I guess I could drill a hole in a panel, mount the shaft, mount the panel on a hinge, and mount that inside the chassis, or I could just mount a pillow block on a hinge in the chassis.
Since this is DIY, I've stumbled across a sealed ball bearing shaft that I can mount onto a hinge, and it cost $.99. This is a little long (2") and complete overkill, it also requires me to make a custom bracket, but hey, that's what DIY is all about.
I'm probably going to try this out, you all can make fun of me later, when I post the completed project......if I ever finish!
Old 20th December 2003, 01:02 AM   #32
RIC is offline RIC  United States
Get your old junk roller blades out and take a good once over at the bearings, thay come out fairly easy, and you might find what your looking for.
Old 20th December 2003, 03:58 AM   #33
li_gangyi's Avatar
No roller Blade is ever junk...I'm a rollerblading fan...hehe...I blade everydae...dun junk it...unless ur wheels are really worn out...seriously though...I think a plastic bush woulr really do well...you dun have to go all the way and use a ball race...if u're really despo and have some specs and stuff..I suggest you look at RS (radio Spares) not Radio-Shiok....Under Industrial Products you have a pretty good range of ball races and bearings...
www.rswww.com
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Polymer bearings as turn table main bearings. binspaul Analogue Source 16 6th October 2009 11:41 PM
such a stupid question (probably) fusion Chip Amps 2 25th January 2008 04:35 PM
Ball-race arm-bearings - lubrication an absolute no-no? Aleksunder Analogue Source 11 22nd September 2007 08:07 AM
X-RAY maybe a really stupid question. andrew_whitham Digital Source 10 19th September 2006 08:46 AM
Stupid Yes/No question Elkaid Solid State 3 4th February 2003 08:26 PM
Copyright 1999-2017 diyAudio
