Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What Cable is This?  Wanna make interconnects.
Old 2nd August 2013, 01:43 PM   #21
qusp is offline qusp  Australia
qusp's Avatar
oh sure, if we are talking about coax that would be just stupid, but we were commenting on the cable posted, which has 4 conductors plus coax. my comments relate mainly to shielded twisted pair. saying to connect coax ground at one end only is totally insane.
Old 2nd August 2013, 02:19 PM   #22
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Originally Posted by DF96 View Post
A shield connected at one end will reduce hum by acting as an electrostatic screen. It won't stop RF, but if you wanted to stop RF you would use coax.
I thought it was the other way round. It will stop RF, which is electric field. But to stop hum, which is magnetic field, you need to connect both ends of the shield in order for the cancellation current to circle.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 2nd August 2013, 02:23 PM   #23
Did it Himself
My advice would be to use PTFE cable simply because the insulation doesn't shrink back or turn into a melted mess. Very useful if you are a beginner to soldering. RG-316 or RG-179 is easy to get hold of and inexpensive.
Old 2nd August 2013, 04:29 PM   #24
DF96 is offline DF96  England
RF is electromagnetic, so can be picked up from either field. The twisting, if done properly, will reduce magnetic pickup. As the signal is not balanced there is still the possibility of electric field pick up which the shield will stop.
Hum fields can be electric or magnetic.
However, my advice is to use cable which matches the connections at each end. If unbalanced, like RCA, use coax. If balanced then use shielded twisted pair.
Old 2nd August 2013, 11:18 PM   #25
4PLaY is offline 4PLaY  Philippines
I actually do have one of these too:
Old 2nd August 2013, 11:23 PM   #26
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Why not just buy these "SWAN" brand twin coax from DEECO and be done with it?
no need to whack your brain over some copper wires wrapped in plastic, it tell you and many here will agree, there is no magic in those.....
FWIW, these "SWAN" cables are japan made, i was told...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 2nd August 2013, 11:34 PM   #27
Does having balanced and unbalanced connections have anything to do with the type of equipment used (e.g. USBDAC to AMP)? or just the input output ports (e.g. RCA, XLR,)?
Does it mean that since I'm using RCA connectors, this means I have unbalanaced connections already therefore I should just use COAX? Then if so, what is the advantage or disadvantage with using shielded twisted pairs on RCA interconnects?
Old 2nd August 2013, 11:37 PM   #28
Seems you know exactly what these are AJT. this is also a SWAN and it is a twin coax. It also does say "made in japan" printed on the cable.
I also have a coax and a twin coax instrument cable. These are all used surplus cables I have lying around. I'm only trying to figure out which one to use.
Old 2nd August 2013, 11:41 PM   #29
TonyTecson's Avatar
depends on what you are trying to achieve...
unbalanced because one side is referred to ground...
balanced because the two wires are floating wrt to ground...
i assume that your dac have output buffers that are lowish in output impedance(less than 1000 ohms) and that your power amp has input impedance greater than 10k ohms..
so that if the length of your cable is just about a meter, then i suppose you can use a twisted pair....
but using a coax is always a good practice....
Old 3rd August 2013, 05:41 AM   #30
May sound ridiculous but the cables im making are about a foot long. And since i have everything i need for free im just gonna make both coax and twin. Try them out and see what the differences are. I don't think there will be a huge audible difference but what the hey. If the experience teaches me to solder then win win
Sent from my GT-N7100 using Tapatalk 4 Beta
What Cable is This?  Wanna make interconnects.Hide this!Advertise here!
make DIY interconnects cable? graks Parts 0 5th October 2005 05:49 AM
new here -- wanna make my first small amp zx3chris Solid State 11 31st October 2002 09:48 PM
Copyright ©1999-2017 diyAudio
