Photoresist Anti-etching Blue Paint - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th July 2013, 02:41 PM   #1
elektryk's Avatar
Default Photoresist Anti-etching Blue Paint
Hi, anybody try it for make PCB?
There is a few seller on ebay, who sell this, for example 100g Photoresist Anti-etching Blue Paint for DIY PCB dry film replacement | eBay
Code:
http://www.ebay.pl/itm/100g-Photoresist-Anti-etching-Blue-Paint-for-DIY-PCB-dry-film-replacement-/190741561459?pt=LH_DefaultDomain_0&hash=item2c69154073
What is better, this or photoresist film?
EDIT:
Please use link in the code window.
Old 20th July 2013, 10:18 AM   #2
elektryk's Avatar
I have ordered it, we will see whether it works.
Old 6th February 2014, 02:19 PM   #3
elektryk's Avatar
It works fine with Nitro diluent, I'm using Seno 4007 developer after exposing.
Old 6th February 2014, 02:42 PM   #4
Did it Himself
richie00boy's Avatar
This kind of stuff used to be used years ago in the old etch resist pens. I used one to do my first PCB about 24 years ago.
Soon moved onto transfers then printing transparancies and UV exposure.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 6th February 2014, 11:25 PM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Its not the same.
The one you mention was used to directly draw the tracks and pads by hand.
This one is applied to all of the copper surface, then the image is transfered photographically, using a negative.
Old 7th February 2014, 07:31 AM   #6
Did it Himself
Ah ok, couldn't get the link to work.
Now used the link in the code window. Spray on resist is bad enough, but this looks even worse. Fair enough the poster got a result, but I wonder how intricate his PCB was.
Old 7th February 2014, 07:53 AM   #7
Off topic post
On your website, RELAY IS MISSING in the soft-start schematic
Gajanan Phadte
Old 7th February 2014, 08:32 PM   #8
Did it Himself
Thanks Gajanan, but R5 depicts the relay coil.
Sorry for the off topic.
Old 7th February 2014, 08:53 PM   #9
elektryk's Avatar
This resist isn't as bad as looks, here is PCB with SSOP28 package (it was made with one layer printed on transparent foil on inkjet).
Using airbrush gives better results, this PCB isn't the best which I have etched, because this one wasn't painted precisely, scratches degrades PCB quality.
Old 17th February 2014, 01:42 PM   #10
Default Nitro
Can you tell me what the nitro diluent is that you used? sorry but I'm new at this and have no clue.
Photoresist etching buzzforb Construction Tips 21 2nd June 2013 04:30 PM
What is this blue paint on old TO-92 Motorola parts?? BenY Solid State 5 31st December 2012 12:45 PM
photoresist Stefanoo Parts 21 30th April 2012 07:23 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Photoresist shivela39 Parts 3 26th March 2006 04:45 AM
Copyright 1999-2017 diyAudio
