Flat Wire Solutions - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th June 2013, 03:54 PM   #1
Default Flat Wire Solutions
Hi!
I am currently developing an electrostatic headphone and wanted to design a custom cable for signal and bias transfer. The recommended avenue previous companies and DIY'ers would use flat multi-conductor ribbon cable with the Stax connector. I want to go for a more simplified method that has even better capacitance numbers than the basic ribbon cable.
I would like to implement a style of "flat wire" that can handle the large voltage swings (at very very tiny current) as well as hold the 600v static bias without breaking down the insulation around it. This shouldn't be too big of a challenge.
There are some solutions out there right now that are ment for lower voltage solutions such as speaker cable, digital signals, and lighting. Typically all rated around 28 gauge? The zig-zag shape they have cuts down on space but has a few picofarads of capacitance per foot because of it (not so hot).
FlatWire Store sells flat wire for Audio, Video, Data & Lighting
http://www.taperwire.com/speakerwire.htm
Other DIY solutions is (1) get copper tape and do something creative with the insulation. (2) Get some foil inductor and take it apart to use their materials & insulation.
Has anybody been down this path before? Any advice on dielectrics and flat shaped things?
File Type: jpg 4WIRE18GaugeFront__32982.1290442883.1280.1280.jpg (94.9 KB, 68 views)
Old 28th June 2013, 07:54 AM   #2
Chartal is offline Chartal  Canada
Maybe there: Alpha-Core - Standard and Custom Cores from grain oriented silicon steel
240/300 Ohms balanced IEC FM-Plug for flat Dipole Wire and for Disass'y e. g.Quad FM3 tiefbassuebertr Analogue Source 13 4th July 2014 08:56 PM
Wide dispersion by active equalization in a flat (wire) ESL jeronimo83 Planars & Exotics 8 2nd February 2013 05:53 PM
Calculating the length of wire in a flat, slender coil kelticwizard Everything Else 12 27th May 2007 08:57 PM
Flat and Square magnet wire? shallowfu Multi-Way 0 10th February 2007 07:20 PM
Dewire Flat wire at CES Da5id4Vz Multi-Way 9 16th January 2004 04:05 AM
Copyright 1999-2017 diyAudio
