Where to find those solder tag strips? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd June 2013, 04:49 PM   #1
giralfino's Avatar
Default Where to find those solder tag strips?
This is a question that was in my head for some long time.
If you look into this page (more or less in the middle), you can see the use of a solder tag strip for a crossover: CA18RNX
I can buy such a strip, but apart the obscene price for this simple item, I don't find it very useful because it is not easy to connect more that 2 wires together (look again at photo of the finished crossover).
I was thinking that something like this quick drawing could be more useful:
Basically the base is non conductive, all the tags are connected together, but it is easy to remove one or more, so you'll have some series of tags connected: if you need for example to connect 3 wires together, and then also 4 other wires together, just use the first 3 tags, then remove the 4th, and use tag number 5 to 8 for the other connection.
Do such a strip exist? It could be very helpful for building a crossover.
Ralf
Old 22nd June 2013, 05:31 PM   #2
You can buy a dual in line (DIL) version of that first example.
It is most regularly used in Valve/Tube gear where they like to hardwire.
Cut it down the middle for single in line (SIL)
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd June 2013, 06:47 PM   #3
giralfino's Avatar
Do you have a link?
Old 23rd June 2013, 07:35 AM   #4
mjf is offline mjf  Austria
the big electronic parts sellers should have lug-type terminal strips (in german: lötleiste ).........and probably tube parts sellers too....
Old 23rd June 2013, 08:51 AM   #5
giralfino's Avatar
I think you all mean this: Tube-Town Online-Store - Lötleiste 2*10 Kontakte / 38 lo02-10
I've seen those strips, I think they are useful when you have to connect 2 (but no more) wires together. My question is still not answered: on a crossover is not too unusual to connect together 3 or more wires (I have an example of 5! I did it but was a PITA).
Ralf
Old 23rd June 2013, 10:08 AM   #6
KatieandDad's Avatar
Isn't it just easier to join the required number of tags together with a piece of reasonable gauge wire ?
Old 23rd June 2013, 10:21 AM   #7
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
why use solder tags when solid copper wire is better
Old 23rd June 2013, 02:09 PM   #8
Pano is offline Pano  United States
Pano's Avatar
Would something like this do you?
Cinch 8 Lugs, 2 Ground Terminal Strip | 29F591 | Cinch
I use them all the time and they are cheap.
Old 23rd June 2013, 08:50 PM   #9
indianajo's Avatar
The advantage of the Cinch design is that they will hold off 450 V on adjacent terminals. Like a radial lead capacitor +, then two grounds together, then a plus of another capacitor, etc. I use the cinch design to replace $40 each 4 gang can caps with 4 each $3 radial lead caps, rated at up to 10000 hours service life instead of no life rating on the can caps.
Tubesandmore.com triodeelectronics.com and electronicsurplus.com have the cinch design, too.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 24th June 2013, 10:46 PM   #10
Enzo is offline Enzo  United States
Yes, plain old terminal strips like Pano's. Each terminal certainly holds more than 2 wires. They come in various lengths and numbers of terminals
dots or strips for spacers? CharlieM Planars & Exotics 42 21st January 2017 12:59 PM
Group Buy - Ettinger Ceramic Standoffs, Ceramic Strips and Solder Tags herrstagl Group Buys 9 20th July 2013 12:36 PM
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
Why spacer strips and not dots? Penguin87 Planars & Exotics 5 7th October 2010 08:50 PM
Where Do You Buy Your Terminal Strips? sdclc126 Multi-Way 5 5th June 2007 01:35 PM
Copyright ©1999-2017 diyAudio
