Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Trying to build an o2 sensor simulator but car forums are a bad place to ask . . .
Old 13th July 2013, 10:22 PM   #31
DUG is offline DUG  Canada
I had to design an O2 simulator for calibrating a O2 sensor tester we built once.
Isolate your output to prevent ground loops.
The O2 in your car is isolated and goes to two specific wires to the ECU.
I am not sure why you want to bypass the fuel mixture control loop.
This could result in your engine thinking it was delivering the correct amount of fuel and it is not.
It is not all about emissions. "You could burn up your engine" is not just a story to frighten DIYers.
The DIYers that create their own control over the O2 sensor signal still use an O2 sensor to get a reading of what is happening to the mix.
The usual method for narrowband sensor system is to use a wideband sensor and shift the threshold point to the mix that they need.
Those that want power adjust the threshold for more fuel/air when required.(usually turbo systems)
Those that use them to allow the engine to run on a leaner mix (HHO types) shift the mix point the other way. (researched this quite a bit)
They both know that you still have to monitor what the mix actually is.
Hope you learned something.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 13th July 2013, 11:22 PM   #32
Discochicken is offline Discochicken  Australia
Hi Jimmy. I had a quick look through a list of fault codes for your VW. I found over 30 codes related to o2 sensor range/performance, then stopped counting. Also I'm fairly sure the ECM compares the reading from the front and rear sensors, they are related as they're measuring the same gas. I don't find it "strange" at all that you got rid of one code and picked up another. There's 28 more codes waiting for you.... But best of luck ;-)
Old 20th July 2013, 01:16 PM   #33
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
I'm having problems fools the heater circuit. Anyone have old O2 sensors (perhaps broken) for v6 Passat or Audi they can sell me?
The resistance seems to go up as the O2 sensor gets hotter. I don't know what resistance, if any, will fool the computer.
Old 22nd December 2013, 07:07 AM   #34
levanars is offline levanars
can anyone help me.
can i build o2 sensor simulator without led (1.7v@20mA)
Old 22nd December 2013, 05:42 PM   #35
Can i build o2 sensor simulator without leds (1.7v@20mA)
If I can, then how:
1. what components needs instead leds;
2. have any schematic?
Trying to build an o2 sensor simulator but car forums are a bad place to ask . . .Hide this!Advertise here!
Building the O2 - A novices build experience fineaudiolover Headphone Systems 0 1st June 2013 10:09 PM
http://www.diyaudio.com/forums/analog-line-level/181105-mezmerize-build.html#post2432 AndrewT Analog Line Level 0 14th January 2011 11:11 AM
Bad Car Amps Gone Worse... sousmielie Car Audio 25 28th June 2008 10:39 AM
I want to build car smps and car amplifier himanshuraval Car Audio 0 20th February 2004 12:40 PM
Copyright ©1999-2017 diyAudio
