COAX " cables antenna" - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th June 2013, 05:15 PM   #1
Default COAX " cables antenna"
hi ALL,
I wanty know , if exist 150 ohms - impedance characteristyc - of a coax ,solid core ,cable and wher eventually I can purchase some meters ( a lot....)
thanks for reading,
by
Paolo , PHASELESS - HIGH END ,LOW COST SPEAKERS handcrafted in ITALY.
Old 18th June 2013, 06:21 PM   #2
DF96 is offline DF96  England
Strange as it might seem, Googling '150 ohm coax' might answer your question.
Old 18th June 2013, 08:04 PM   #3
Speedskater's Avatar
Paolo, why do you need 150 Ohm co-ax?
Is it for a radio antenna?
Kevin
Old 19th June 2013, 05:40 PM   #4
Default why 150 ohm coax solid core
Hi, because i put one in go and one in return for my digital hiugh end DIY cabkles......Van den Hul S/VHS 2-75 is not more reperible, unfortunately it was exceptional how digital cables.... ssshhhhh! top secret....
thanks paolo
by
Old 19th June 2013, 06:08 PM   #5
Digital audio usually needs 75 ohm cables. To get that with 150 ohm (why??) you would parallel two cables together; the result would probably be bad jitter. I don't understand what you mean by 'go' and 'return'.
Old 19th June 2013, 07:29 PM   #6
marce is offline marce  United Kingdom
Heretic
Possibly separating the signal and its return path, the worse thing you can do to a digital signal...
Old 19th June 2013, 07:38 PM   #7
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by inertial View Post
hi ALL,
I wanty know , if exist 150 ohms..
The old twinax computer cabling used in AS400 systems: 150 Ohm Twinaxial Cable from Allied Wire and Cable, Distributor of Belden Cable
Ears aren't microphones.
Old 19th June 2013, 09:42 PM   #8
Well, I did wonder but surely nobody could be that daft? That would mean that some people fret over exactly which BNC they use, while someone else happily uses a 300ohm 'balanced' line. It is fortunate the digital audio signals are so robust!
Old 20th June 2013, 11:48 AM   #9
Heretic
Thinking about this further (the mention of S-VHS cable threw me) are we talking about:
Twisted pair within a shield or
two co-ax cables within a single shielded cable?
S-VHS used the latter, but the first can be used for balanced signals and digital LVDS
Old 20th June 2013, 12:12 PM   #10
stormsonic's Avatar
Yeah, and twin-lead 300 Ohm cable from old TV antenna is twice as good as "just" 150 Ohm
3-way center-channel using SEAS 7" coax and 7" woofers jeffreybehr Multi-Way 6 5th June 2012 02:04 PM
HELP !! Getting " Clicks " when using sPDIF coax digital out arupg Digital Source 7 11th October 2010 05:48 PM
Best Coax Choices (8" or 10") doug20 Multi-Way 6 21st August 2009 03:04 PM
Update on " THORS TACKHAMMER 5" coax THOR Multi-Way 17 11th July 2004 08:04 PM
Does anyone know the brand "QED" for cables & interconnects? Bricolo Parts 7 25th June 2003 10:32 AM
Copyright 1999-2017 diyAudio
