Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Audionote copper mylar in oil failed
Old 1st June 2013, 04:01 AM   #11
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Default Oils Ain't Oils....
Soybean oil is normal for modern industrial capacitors.
I don't know what the additives are, but they make the oil red coloured, thick, gooey and it stinks....really bad.
In the old days industrial capacitors used some kind of oil with PCB additive to inhibit moisture ingress...PCB's are now banned and are a declared toxic waste
Be aware that caps in old tube gear may contain PCB's.....modern caps should have markings saying 'PCB free'.
Yush? disease - Wikipedia, the free encyclopedia
Appropriate vegetable oils which may be applied in the oil mixture of the present invention are selected from sunflower seed oil, rapeseed oil, soybean oil, castor oil and maize or corn oil.
http://www.gits.kmutnb.ac.th/ethesis...4710185069.pdf
Each capacitor is filled with our patented, environmentally-friendly ESO (Epoxidized Soybean Oil). Used as the dielectric fluid, the soybean oil protects metallized film from corrosion, aids optimum heat transfer, and helps suppress the degrading effects of corona, which may otherwise cause premature failures. Proprietary processing with vacuum and heat cycles ensures complete removal of moisture, resulting in superior capacitance stability and long term reliability.
Aerovox Capacitor Specifications
Dan.
Old 5th June 2013, 08:00 AM   #12
semperfidelis is offline semperfidelis  Philippines
Originally Posted by eherdian View Post
Hi guys..
I just want to share my experience with Audionote copper mylar in oil caps.
I built 300B SE amp base on Audionote Quest but modificated to stereo amp instead of monoblok amp. I used Audionote caps 0.33 uF/630v copper mylar in oil (copper tube, black label not white and diameter bigger than current Audionote caps). I bought 1 pair from Partsconnexion Canada (they are a nice seller doh) about 1 years ago and just 6 months ago I finished the project and started to fire up the amp and sounds very lovely.
2 days ago I turned the amp and playing some vocal music, everything seems going ok until 2 hours during playing some slow music sudently I heard very bad distortion on my left loudspeaker and the volume seems decrease. I smelled bit burnt odour near the cathode resistor (it's very hot on that resistor). I hurry up turn off the amp, get my multimeter and checked everything until I found that the Audionote coupling cap was shorted and pass through 271vDC!!
Maybe you guys ever have experienced fail caps as I did? I've sent complaint to Audionote contact via email and haven't any reply until 2 days maybe they too busy
I questioned them about the quality control and cap durability or maybe I just unlucky hehe.....I never experience any problem with other cap I use until now (I also use Jensen copper in oil, Mundorf Silver Oil, Supreme, Dynamicaps, Jantzen Silver, etc)
For now I doubt to use Audionote cap again, maybe I will try Jensen paper tube instead buy again AN caps
cheers....
Erik
I had this experience twice with the audio note amp: I used the best film cap to replace the second failure, but my customer did not like sound outcome.
Old 5th June 2013, 09:14 AM   #13
davidsrsb is offline davidsrsb  Malaysia
This makes me wonder if the failure mode creates some euphonic distortion before the fatal short
Old 6th June 2013, 05:32 AM   #14
eherdian is offline eherdian
I agree...the AN caps sounds glorious and cannot competed by non oil film cap..
I've replaced that AN with Mundorf Silver in Oil and still Mundorf cannot compete with AN sound.
The good news is I just got response from Martin AN UK. I get replacement for my cap with a pair new batch AN caps. I have to send back the faulty cap to them.
They explain that the AN cap I got from PCX was the first batch of their production which is some troublesome (they admit it in their AN website). I hope the new pair much better than the old pair.
I also bought a pair Jensen paper tube so I can compare the sound with the new AN caps..
cheers....
Old 6th June 2013, 06:30 AM   #15
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Well, castor oil has been used as a dielectric in high voltage energy storage caps, but it is rigorously refined for that duty.
Old 6th June 2013, 07:07 AM   #16
Bibliophile is offline Bibliophile  Australia
Originally Posted by wrenchone View Post
Well, castor oil has been used as a dielectric in high voltage energy storage caps.
So, no surprise if they sometimes s##t themselves.
Old 6th June 2013, 02:50 PM   #17
cheers....
thanks for the the information. I think I have some mailing to do. Thanks again.
Old 7th June 2013, 09:04 PM   #18
bambadoo is offline bambadoo  Norway
This is what AN says.
BIG Capacitor News!
Well, the really big news is that we have moved all our copper foil signal capacitors away from using a paper dielectric to using the same mylar that we use in the silver foil, but we retain the oil, so all our copper foil signal capacitors are now oil filled using mylar instead of paper, one slight abnormality, we have two print machines for these caps and for one of them we have not got the new print blocks that say “copper foil/mylar in oil” yet, so they still say paper in oil, however the print is now white instead of black, so we can see the difference, I know this is confusing, but it is temporary, I can assure you!
Why did we move to oil filled mylar from oil impregnated paper you may well ask?
When truth be told we have been experiencing increasing problems with the failure rate of our paper in oil capacitors over the past 3 to 4 years and despite a major research program into the causes of this increasing break down rate we have really come up with a blank, which makes me suspect that the cause has to do with subtle changes in the chemistry of the paper, the oil or some other key part of the caps, possibly due to new environmental requirements imposed on the production of the paper, who knows? Anyway, when it became obvious that we were unable to fully establish and rectify the cause, my engineers and I decided to give mylar a go again as the first experiments we did with oil imperegnated mylar was not sonically satisfactory, so this time we changed the construction to oil filled, the materials sealing the capacitor and the way we connect the foil ends to the wires and voila! After some running in, the new mylar/oil filled capacitors actually sound better in most respects than the old paper signal caps they replace, only real drawback in my view is that they take nearly twice as long to run in and sound quite a bit worse than the old paper/oil type when they are new, so there you are, you don’t get something for nothing!
Due to the problems that have emerged with the paper in oil signal capacitors I have decided that we should replace any faulty copper bodied Audio Note copper foil paper in oil caps that any of you have*, all you need to do is send them back to me here at Montefiore Road in Hove and they will be replaced free of charge with one of the new mylar versions. One thing though, you need to mark each capacitor up with what is wrong with it, if you don’t mind.
* Please remember that this replacement offer only covers copper bodied Audio Note capacitors and DOES NOT cover the previous yellow / gold bodied versions.
As mentioned in both the Audio Transformer and Wire & Cables Sections, the cost of most raw materials has gone through the roof over the past 3 - 4 years, our bulk purchasing of foils, wire, HiB and nickel have only started seriously affecting our cost over 2007, in spite of this I have decided not to increase our prices yet, although if the cost of the raw materials do not stabilise or come down over the next few months, prices will have to rise.
Old 13th June 2013, 10:47 AM   #19
esltransformer is offline esltransformer  Georgia
Banned
Default MKV
Don't forget the good old and still new available MKV capacitors. Original produced by Siemens (Germany). Later Siemens sold the MKV to Matsuhita and now Epcos owns it.
MKV are double metalized paper with polypropyleen dielectic. They sound super (Allen Wright from Vacuum State used them).
I still have much 0,22F/900V MKV in my basement.
Ohh, and Siemens used the more reliable and even better sounding mineral oil
Old 14th June 2013, 09:30 PM   #20
Thank you esltransformer for such valuable information.
Audionote copper mylar in oil failedHide this!Advertise here!
WTB pair caps Duelund VSF Copper Foil 6.8 uf or Mundorf Supreme Silver Oil 6.8 uf kazantip Swap Meet 3 10th October 2011 08:49 PM
FS: Audio Note 0.47mf Copper Paper in oil Caps jdeitch11 Swap Meet 1 21st March 2011 03:20 AM
For Sale: Audionote PIO Caps Copper Foil QSerraTico_Tico Swap Meet 3 12th February 2011 04:38 PM
Mundorf Silver-oil VS Jensen copper foil 100db Tubes / Valves 24 5th March 2006 02:12 AM
