Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th December 2003, 03:08 PM   #11
lgreen is offline lgreen  United States
lgreen's Avatar
Default Switches....NKK
Wright, thanks, I've emailed you the .pdf.
I've wanted some NKK switches but they were out of stock at mouser/digikey. So I now ordered some switches directly by calling NKK. They were really nice about letting me order some with my credit card over the phone. If you don't get samples and can't find the exact ones you want at a distributor, give them a call.
What's the deal, you asked for postings of everyone's switches and got only a single reply on-topic?
I'll post pics when I get them.
Old 9th December 2003, 04:09 PM   #12
Well, I guess it depends upon your definition of cool.
As I'm metal working challenged, I'm constrained to circular hole mounting switches. I use a standard 15/32s" mount dpdt switch that I sourced from Hugh. Its a 20A 125v, 10A 250v, 1 1/2HP 125-250V (for those inductive loads from transformers or motors).
Other than its more than adequate ratings it offers the following -
Its bat handle and the knurled mounting nut is finished in a matte black powder coat and IMO it looks really kewl and retro.
It also allows (iff'n you've a mind to) to configure it not only as an on-off switch, but also, while still fusing the hot lead, one to reverse the hot and neutral wires on the power supply. This dpdt switch is on-off-on. This allows one to potentially minimize ground potential without resorting to 'cheater plugs' and not compromising the safety funtion of fusing. Regardless of this option, it still looks really cool...
Alternatively (while not nearly as cool looking) consider the W51, rocker thermal breakers from P&B. Mounting in the same cutout as many rocker switches, it combines the function of a switch and fuse. These thermal breakers are not as succeptable to contact welding and will provide significantly lower on resistance that the typical combination of a switch and fuse.
http://www.mouser.com/catalog/616/944.pdf
Old 9th December 2003, 05:44 PM   #13
Wright is offline Wright  United States
Send a message via AIM to Wright Send a message via MSN to Wright
Thanks lgreen, I received the pdf and will give it a thorough reading. Pkmap do you have any pictures of the switch you used?
George
Old 9th December 2003, 06:08 PM   #14
Wright,
The toggles are the ones shown in these pictures -
http://www.audiocircle.com/circles/m...bum.php&page=1
The handiwork is not mine, its too well executed.
Source for Cool CIT Switches with LEDs kurtbauer Solid State 1 22nd August 2007 12:40 AM
Where to get cool-looking knobs/switches/feet? gmikol Parts 9 4th June 2007 07:37 AM
Switches LizardDefence Everything Else 5 1st June 2005 08:52 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 16th April 2004 11:33 PM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 05:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
