| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
I read in a number of places to ground the calbe shield at the source end rather than the amp. My question is, though wouldn't that send interference into the more sensitive component?
#2 |
I've been doing this for some time now with my guitar cords, and work's fine. I use two conducter mic cable, one conducter is hot / signal, the other is ground, both end's. and the shield is only at
signal end. from what I recall, it prevents signal loss for one. plus a cleaner signal path / loop. maybe as in signal phase? anyway the trick is too get the shield in the plug, ect... housing but not touching ground. most likely you know all this and it's probably e-realavent to your ? |
| Toroid transformer, shield or not to shield? | bays_9a5tt | Digital Line Level | 10 | 21st December 2008 02:10 PM |
| Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... | EchoWars | Solid State | 37 | 3rd August 2008 08:50 AM |
| active cable shield driver in a phono amp -- does it make sense (noise- or sonicswise | Onvinyl | Solid State | 0 | 1st June 2008 09:53 AM |
| LM3875 kit grounding, optimal grounding for separate amps and psu? | findog | Chip Amps | 9 | 16th May 2005 09:27 PM |
| Shielded cable for internal amp wireing: where do I connect the shield? | Bricolo | Parts | 11 | 26th June 2003 01:26 AM |
| Page generated in 0.06224 seconds (72.57% PHP - 27.43% MySQL) with 10 queries |
