Leaded or unleaded solder ? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th May 2013, 07:40 AM   #11
blakkshepeaudio's Avatar
Originally Posted by Steve Eddy View Post
snip
Yeah, well some people report putting photographs of themselves in their freezers makes their system sound better. So...
You're not suggesting this doesn't work, are you ?
blakk'n'dekka
Old 6th May 2013, 08:01 AM   #12
Yep, works great especially if the photo is in black and white.
Jan
Old 6th May 2013, 08:14 AM   #13
What, the blacks get blakker and the whites get... well, you know....?
Has anybody experimented with listening in a coldroom / industrial freezer?
Think of the tweak possibilities...
Perhaps soldering at sub-zero temperatures (good luck with that) might be the answer. Or maybe using solder with a melting point below zero which mandates operation in cold conditions to avoid the circuit falling apart.
Oh the opportunities for 'scientific research' !
blakkhumour
Old 6th May 2013, 10:13 AM   #14
The resistance of any good soldered joint is very low. The resistance of a dry joint is all over the place and unstable. Traditional tin/lead is still the best way to avoid dry joints and as a bonus, the lower melting point makes component damage much less likely.
Old 6th May 2013, 11:42 AM   #15
tvi is offline tvi  Australia
tvi's Avatar
nihon superior sn100c Tin-Copper-Nickel-Germanium
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 6th May 2013, 12:41 PM   #16
zigzagflux's Avatar
63/37 all the way. Only exception would be when the components to be soldered contain silver plating, at which point I use Cardas Quad Eutectic. Might be filled with a bit of marketing, but it really does wet beautifully and even smells pretty good as a bonus. But the leaded kind, still.
Old 6th May 2013, 01:07 PM   #17
post15 lnk:
Can anyone see where it tells us if this quad is a eutectic?
or it's freezing temperature?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th May 2013, 01:17 PM   #18
Found it.
sn100c is not a eutectic.
Melting point stated as 228C
That's 44C, 79F degrees higher than 63/37 eutectic.
I have not found the pasty range (melted to frozen range). Maybe they are afraid to tell us !
regards Andrew T.
Old 7th May 2013, 12:46 PM   #19
marce is offline marce  United Kingdom
Ime tin/silver sounds really good, lead/tin/silver sounds really bad.
No way can you hear differences between solder joints...
Old 7th May 2013, 01:58 PM   #20
Steve Eddy's Avatar
Joints? Hell, I remember when IAR introduced their Wonder Solder. Someone purported hearing a huge difference after they'd reflowed just ONE solder joint in the circuit with it.
se
The Audio Guild
audio digital delay chip in leaded dip pkg.? Bob Richards Parts 0 16th September 2011 10:59 PM
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
3-leaded russian PIO caps moonbird Parts 6 4th February 2010 01:10 AM
FS: AD815AY Leaded SIP version Panelhead Swap Meet 34 21st April 2007 04:08 AM
Copyright 1999-2017 diyAudio
