diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Welwyn "Metox" resistors (http://www.diyaudio.com/forums/parts/234801-welwyn-metox-resistors.html)
Dagwood 25th April 2013 06:10 AM
1 Attachment(s)
Hi
Does anyone recognise these??? or better still have a datasheet???
So far I've got next to knowhere on the net:headbash:
Metal oxide
Wattage??
Voltage rating??
Blah
Cheers
Wino 25th April 2013 11:34 AM
Pretty old stuff: METOX - Reviews & Brand Information - WELWYN ELECTRIC LIMITED BEDLINGTON ENGLAND , - Serial Number: 72079900
Tolerance: can maybe be worked out by the colorbanding?
Wattage: physical size??
Sorry for not being able to give more informatio.
//Wino
Dagwood 26th April 2013 12:47 AM
Yeah, they are pretty old
5 colour bands, first 3 are value and the last 2 are both violet on all of the values ive got. Onje must be tolerance but not sure about the other
Think they may be 2 watts??
Cheers
colincci 10th December 2014 08:17 PM
Did you ever find a datasheet on these. I have a large quantity of them. They are sized about right for a 2W resistor, but I believe they are actually only a 1/2 watt. An early metal oxide, supposedly a tight tolerance for the time (2%).
Dagwood 12th December 2014 09:46 AM
Hi Colincci
No I never did but I think you are right on the current ratings.
Cheers
colincci 14th December 2014 07:55 PM
1 Attachment(s)
Hi Dagwood
I just finished sorting through the ones I have. A number of the boxes were label RL20. Both the boxes and the resistors appear identical to the ones labeled F20. I believe the RL20 were a newer, or replacement version of the F20. I was able to find a data sheet on the RL20 series. Link is here: http://www.ttelectronicsresistors.com/datasheets/RL.pdf
I will attach the pdf just in case the link disappers in the future.
Dagwood 15th December 2014 06:04 PM
Thanks colincci
Great work :) They definitely look the same as mine. I've sorted mine as well and will certainly look the part in tube amps
Case closed:)
Resources saved on this page: MySQL 18.75%
