Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Never want to break a tap again? Nut inserts!
Old 30th November 2003, 04:06 PM   #1
Doh is offline Doh
Default Never want to break a tap again? Nut inserts!
Hello everyone,
I'm currently in the process of putting together the chassis for my APOX kit. While I was shopping McMaster Carr for hole taps and drill bits, I came across some stainless steel threaded nut inserts. (McMaster Part number 98560A526) I think they are also called A-T series nut inserts.
Does anyone have any experience with these? If they work, they seem like a fool-proof way of creating threaded holes without the possibility of breaking taps etc.
I think that, instead of buying the very expensive installation tool, it would be possible to install these with a suitable length screw, allen wrench, and something to use as a spacer like a drill bushing (McMaster part number 8509A11, for example)
Thanks in advance!
Doh
Old 4th December 2003, 07:42 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Hmm...cutting thread actually isnt that big a deal.....
Just make sure you use the right lubricant.
For steel, brass, copper and titanium, use cutting fluid( rocol and others).
For aluminium, use alcohol.
If done like that you should never brake a tap......that is if you remember to buy a new one now and then....old taps are bound to brake sooner or later (mostly sooner)
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 4th December 2003, 08:04 PM   #3
Doh is offline Doh
Thanks Magura,
I ended up deciding that drilling a small hole was quite a bit more preferable to drilling a big one and using a nut insert. I used Peter Daniel's technique of using a drill gun, with a makeshift drill guide and the holes came out beautifully.
Doh
Old 4th December 2003, 08:05 PM   #4
Petter is offline Petter
If you chassis is Aluminium, and relatively thin skinned, the threads won't last. Inserts is the way to go in that case.
Petter
Old 4th December 2003, 08:08 PM   #5
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Never want to break a tap again? Nut inserts! Send a message via AIM to Peter Daniel
Anything that is 1/8 " , or so, is not a problem. After all you assemble it only once, right?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 4th December 2003, 08:11 PM   #6
Magura's Avatar
sure....once a week
Magura
Old 4th December 2003, 08:15 PM   #7
Doh is offline Doh
I think the threads will be ok. I'm using 3/8" screws to hold a 4mm panel (without threads) to the back end of my APOX chassis. For most of the chassis, I elected to use epoxy to hold the panels together, as the sides are made from 1/2" aluminum bar. I'm incredibly pleased with the way the project has come together and have posted pics in the APOX thread just to show off.
http://www.diyaudio.com/forums/showt...106#post276106
Never want to break a tap again? Nut inserts!Hide this!Advertise here!
Break in wicked1 Tubes / Valves 0 18th February 2008 08:30 PM
Sub Break In CARTRulz Subwoofers 16 4th September 2006 04:40 AM
Source of black hex screws, threaded inserts etc in Australia? David Gatti Multi-Way 18 29th November 2005 11:27 AM
Threaded inserts versus T-Nuts tiroth Multi-Way 7 10th December 2004 02:20 AM
How to break-in a new GC TheDriver41 Chip Amps 15 21st October 2004 05:34 PM
Copyright ©1999-2017 diyAudio
