Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd December 2003, 04:57 AM   #11
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by jean-paul
Yeah, what about them ?
Hehe
I was just wondering if you tryed, and whod it sounded.
Old 3rd December 2003, 08:39 AM   #12
Bernhard's Avatar
Okay, I will put some in my CD and the rest on ebay.
Anyone tried Siemens MKL ?
Old 3rd December 2003, 10:46 AM   #13
Bricolo's Avatar
Mail me if you want to sell some
Old 3rd December 2003, 11:45 AM   #14
Bernhard's Avatar
Have something to trade ?
I have more than 200 pieces...
Old 3rd December 2003, 02:41 PM   #15
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Tube geeks united...
snip...Although I am very fond of OSCON in digital gear I am surprised that they are recommended in tube amps. My experience is that they don't sound optimal in the analog signal path...snip..
Strange comment from a tube geek, tube geeks hear unmeasurable artefacts all the time
..snip
I don't usually rely on references, but depend on the strength of my own argument to justify my point. However, I couldn't resist this, which I read today in Morgan Jones' 3rd Edition of Valve Amplifiers. Page 222 includes this:
~ , Sanyo's "OS-CON" range of capacitors uses an organic semiconductor electrolyte that significantly reduces ESR. Reduced electrolyte resistivity allows deeper etching, resulting in higher capacitance per unit volume, and therefore reduced inductance. OS-CONS therefore have measureably better high frequency characteristics, and would be ideally suited as cathode bypass capacitors, if it were not for their extremely high price.
Morgan is usually on-target with his judgements.
The capacitors in this case are "stock".
For anyone with an interest in valves, Morgan's 3rd Edition is a must. I recommend it highly.
Edit: That'll be £10 please Mr Jones
Old 3rd December 2003, 04:27 PM   #16
Bernhard's Avatar
Default Did some research today
The OSCONs that I have are purple and say 105°, but have magnetic leads, so nothing for the signal path, but for digital decoupling should be very good because 0,4 Ohm @ 100kHz.
Found a website that says @1Mhz and 15MHz better ripple rejection than BG
What about Rubycon GXF 10000µF/10V ?
The thing is I plan to build low voltage rail classA amp and 10V caps are perfect.
I wonder if the magnetic leads of the OSCONS do harm if they are in the analog psu.
Also TO3 Fets are magnetic and a lot
Old 3rd December 2003, 05:54 PM   #17
Bricolo's Avatar
Money?
Or a CD player that I don't use much (philips cd940)
Old 3rd December 2003, 08:13 PM   #18
Bernhard's Avatar
Thanks, not another CD player
Maybe make an offer total price for how many pieces you want.
I have 220 and want to keep 40 for own use, the rest 180 pieces I can sell.
Looks like it is the cap for 5V supply of DAC.
I am looking for nonmagnetic resistors, Jahre mica caps, TDA 1541 S1 , Hitachi TO3 fets or substitutes like buz 900 series.
Old 3rd December 2003, 08:25 PM   #19
Bricolo's Avatar
I will never find the need for 180. Maybe 20, or less.
But I have nothing to trade, what's your price?
Old 3rd December 2003, 08:28 PM   #20
jean-paul's Avatar
Wrong thinking, Bricolo ! You'll never get that much wanted stock this way
It's only audio
sanyo dca 20 raindog Chip Amps 2 7th June 2009 02:11 PM
Sanyo MV-AX caps. Any good ? Elberoth Digital Source 1 24th December 2004 04:42 AM
Sanyo Plus A35 Mr. Bungle Solid State 0 30th July 2004 09:34 AM
Sanyo DCA 411 kvarnis Solid State 1 29th July 2004 02:56 PM
Copyright ©1999-2013 diyAudio
