6 pin capacitor??? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th April 2013, 01:37 AM   #1
bullpeters's Avatar
Default 6 pin capacitor???
my vishay MKP 200uf film caps have six pins!!!
cant find any indication in the data sheet as to which pins are wgich?? Confused and need some advice.
Please
Old 10th April 2013, 02:00 AM   #2
DUG is offline DUG  Canada
Ohmmeter
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 10th April 2013, 02:10 AM   #3
grufti is offline grufti  United States
grufti's Avatar
Manufacturer - Part Number - Datasheet? I'm asking because I didn't find a very good match with the information in your message.
It's usually like this:
Old 10th April 2013, 02:18 AM   #4
Jay is offline Jay  Indonesia
Banned
Strange that you have datasheet but not the required data Ime there is usually printed code to describe the +/- pins. It can be many caps in one package or just one cap with supporting pins. Check again any printed codes (or molded on the base near the pins), or other graphics code and painted pins
Old 10th April 2013, 02:43 AM   #5
bullpeters's Avatar
Its a vishay MKP 200uF. 450v Its grey, square, has 6 pins out the bottom and no markings anywere. The data sheet indicates six pins but not how they are connected. think i have it sorted with the meter but i would like to Know!@
Old 10th April 2013, 03:04 AM   #6
bullpeters's Avatar
MKP1848 720 454Y5 - VISHAY ROEDERSTEIN - CAPACITOR, MKP, 500V, 200UF | Farnell United Kingdom
Old 10th April 2013, 03:12 AM   #7
grufti's Avatar
You're right, I couldn't find anything there either. Take my poached drawing [from another Vishay datasheet] and DUG's elaborate "ohmmeter" message. Together they ought to provide the answer and nothing could possibly go wrong.
Old 10th April 2013, 03:18 AM   #8
Either the pins are connected to one end of the cap or the other or are just for support.
Sorry, I've run out of ideas.
ohmmeter.
Old 10th April 2013, 03:25 AM   #9
bullpeters's Avatar
Yes. Three pins on one side continuos
Same on the other. Plates in between. 6 pins to stick it to a PCB
If I was making them I might add a couple of dots or something. They don't give them away!!(the capacitors)
Old 10th April 2013, 04:21 AM   #10
Banned
200uF 500V MKP should be very big. Strange. I guess the 3 pins are connected to each other.
Min 9-pin or 7-pin sockets to fit octal-sized holes? ray_moth Tubes / Valves 8 1st January 2008 05:15 PM
WTB: dual 8 pin soic to single 8 pin dip adaptors Spev Swap Meet 0 13th July 2006 01:21 PM
What is the 3rd pin for on 3-pin 'lytics? (quick answer needed) SimontY Parts 7 5th March 2005 02:10 AM
Capacitor on the adjust pin LM338 ebijma Chip Amps 6 12th October 2004 05:35 PM
Difference between 3 pin and 2 pin capacitor swede Solid State 10 25th October 2002 06:41 PM
Copyright 1999-2017 diyAudio
