Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Could you identify this part?
Old 5th April 2013, 11:40 AM   #1
michouthefirst is offline michouthefirst  Canada
Default Could you identify this part?
Hi all, I received a bunch of items and this one I could not identify.
Old 5th April 2013, 12:12 PM   #2
ticknpop is offline ticknpop  Canada
It's a spare part from the Tardis, I believe the Doctor would pay big bucks for one.
Old 5th April 2013, 12:32 PM   #3
Good, because I have 20 of them
Old 5th April 2013, 12:37 PM   #4
lcsaszar is offline lcsaszar  Hungary
optocoupler?
Old 5th April 2013, 01:19 PM   #5
It looks like it is not. Putting an ohmmeter between the 2 "C" terminals reads a few ohms whatever the polarity is. The same goes if I read between the "In" and "Out". Resistence is infinite between any "C" and "In" or "Out".
Old 5th April 2013, 01:48 PM   #6
Elvee is offline Elvee  Belgium
Elvee's Avatar
They look very much like delay lines. They could also be filters.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 5th April 2013, 02:05 PM   #7
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
What you measure is compatible with a line/RF filter.
A low DC resistance L from input to output, "maybe" same between grounds ("C" might mean "common" , oldspeak for Ground) and one or more low value capacitors from hot to ground.
*If* you were wishing to analyze it or something, drive it with a sweep signal, load it with something, 10K is as good as anything else to start, and measure/trace what comes out.
Old 5th April 2013, 02:15 PM   #8
tauro0221 is offline tauro0221  United States
I agreed with Elvee. It is possible that it is a delay. They used something like that in old computer memory and analog scanners. Since you have 20 what about breaking one apart and see what it is in inside.
Old 5th April 2013, 03:39 PM   #9
simon7000 is offline simon7000  United States
Engineered Components Company Delay Line P N TTLDL 25M | eBay
Shows a more modern unit with drivers.
Old 5th April 2013, 03:54 PM   #10
OK, got it from the eBay description (his description was very hard to read since it has numerous items and the guy had a very long description with all sorts of fonts and colors).
Anyways, here it is:
60pF input, 20uH bridge, 60pF output.
So, this seems to be a low-pass filter. Right?
Could you identify this part?Hide this!Advertise here!
Help me identify this part and find a replacement? JGAN Parts 5 7th January 2013 12:33 AM
identify part from car audio amplifier darkkon Parts 5 14th April 2011 04:42 AM
Identify part on SI T-amp pcb (I burned it...) jaste Class D 5 19th September 2008 03:28 AM
Please help this Newb identify this part. Paulcocom Parts 2 11th September 2007 04:18 AM
toshiba sd-3950: help me identify a damaged part xcortes Digital Source 0 24th July 2005 02:30 PM
Copyright ©1999-2017 diyAudio
