Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Aluminium shield for cables DIY
Old 26th March 2013, 10:35 PM   #11
DF96 is offline DF96  England
see post 8
Making your own cable is every bit as barmy as making your own capacitors, but somewhat easier than making your own semiconductors.
Old 26th March 2013, 11:27 PM   #12
payitforwardeddie is offline payitforwardeddie  United Kingdom
I'm working in EMC at the moment. We use copper foil tape for shielding cables. Aluminium foil does not perform well. Earth bonding is better with copper. Conductor Emissions are better with copper. Radiated Emissions are better with copper. Plus you can solder wires to copper easier than aluminium.
Old 27th March 2013, 11:39 AM   #13
inertial is offline inertial  Italy
Where I can find copper foil?
Thanks!
Old 27th March 2013, 12:53 PM   #14
marce is offline marce  United Kingdom
Buy shielded cable, you will get a better result and probably cheeper by the time you have finished messing about.
Old 27th March 2013, 09:43 PM   #15
Speedskater is offline Speedskater  United States
Speedskater's Avatar
First read posts #8 & #14.
But copper foil is useful in other DIY electronic areas.
So I get mine in a hobby/crafts store that deals in leaded & stained glass.
Kevin
Old 28th March 2013, 11:28 AM   #16
OK thanks!
Old 28th March 2013, 11:36 AM   #17
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
tricky to solder aluminium
Old 28th March 2013, 12:10 PM   #18
Einric is offline Einric  United States
Einric's Avatar
Copper roof flashing is VERY common in the construction industry and is available in rolls.
You could also take some RG58 type coaxial cable and pull the center conductor out of it, then you will have a tinned copper "Jacket" to work with.
Larger coaxial cables could be used if you need a different diameter of "Jacket".
I like RG400 since it is silver plated over solid copper.
Old 28th March 2013, 08:18 PM   #19
You can get sticky backed copper foil for electronics, I have a couple of rolls of it, when I remember where I got it I'll let u know, might have been RS or Farnel!
Aluminium shield for cables DIYHide this!Advertise here!
DIY IC: What do do with shield? DreadPirate Construction Tips 2 10th January 2013 09:24 PM
Copper ring as a shield of the main power cables??? zoranaudio Solid State 2 6th November 2009 04:51 AM
ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! ssabripo Everything Else 3 26th October 2006 02:33 PM
Have annoying noise?... want a diy shield... try this one. destroyer X Solid State 17 8th October 2005 10:52 AM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
