Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
PGA2311 pre-amp static discharge problem
Old 6th April 2013, 06:57 PM   #21
kevinkr's Avatar
Post deleted. Defeating safety grounds is always a stupid move, and such recommendations also fly in the face of general forum policy regarding the safety of devices connected to mains. The poster of this gem should be advised that further such recommendations will get the attention it deserves from moderation.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th April 2013, 08:02 PM   #22
dmills is offline dmills  United Kingdom
Sort out the decoupling, which appears to be mostly missing, also look to see if the processor board has the same problem.
73, Dan.
Old 14th February 2015, 10:43 PM   #23
jaylgordon is offline jaylgordon  United States
So glad I found this thread. I got the fully assembled version and noticed the static problem immediately. It was exactly as described above. Moreover, the problem would occur simply out of nowhere, which I'm thinking was static in the environment due to very dry air here.
The bursts pretty much traumatized my 6-year-old daughter. I was going to return the device, but the cost of shipping back to China was over $80. Pretty high even if they said they'd reimburse. So I settled for a "new CPU," but in the meantime I opened the box and noticed there was nothing tied to the ground pin on the mains input.
Not being an engineer, I thought maybe the scheme was a "chassis ground," i.e., there are items tied to the chassis, but I really couldn't be 100% sure. I suspected the problem still had to do with grounding. It just seemed odd to have nothing tied to that grounding pin.
So I think I will tie what appear to the points where the components are tied to the chassis to the ground pin at the mains input, along the lines suggested above. Does that make sense?
Old 26th February 2015, 03:44 PM   #24
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Yes it makes sense, but has it worked? I've grounded everything that can be grounded and I still have the problem but only when I play vinyl, usually when I remove the disc from the turntable, very occasionally during play
I'm out of ideas
Old 26th February 2015, 07:27 PM   #25
I gave up and threw it in the trash. My approach seemed to solve the problem at first, at least when touching the front panel or volume control. But when I nudged the device, it must have gotten some kind of static charge on the inputs (or somewhere) and, bang, it happened again. The seller was kind enough to respond to my questions and even sent me a new CPU. But that had no effect, so I pitched it. No use to me, even though maybe that sounds a little silly.
Old 14th May 2015, 01:30 PM   #26
fantacrazy is offline fantacrazy  Italy
Hi bro...what is The problem?? The pga2311 are two version
One have The 0V to chassis and other nothing to chassis (no earth no 0)
To solved is put chassis at ground but not 0V that in one pcb go by a screw. Check The fixing...
Old 4th November 2015, 10:47 AM   #27
diyinhh is offline diyinhh  Germany
Dear all,
has anybody now found a suitable solution?
I bought the upgraded 2311 Preamp PCB and really asking myself what todo before destroying my LS.
Link: Upgrade PGA2311 Stero Remote Volume Controller Preamp | eBay
Thanks!
PGA2311 pre-amp static discharge problemHide this!Advertise here!
static 'hissing' noise problem hakentt Car Audio 20 14th April 2014 06:22 PM
TDA2616, PGA2311 soundbar noise problem child1 Chip Amps 2 18th January 2013 09:30 AM
Help with LM3886 + Crystal PGA2311 pre-amp kit! Hubba Chip Amps 11 15th August 2011 05:23 PM
Cracking/Static in Pre-Amp TheVille Solid State 2 17th April 2009 07:42 PM
Static Discharge Issues for Zen Amp McJerry Pass Labs 5 26th August 2001 12:41 PM
