Battery Over-Discharge Protection Circuit - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th February 2013, 12:21 AM   #11
If you have a power Schottky across each cell, as soon as the cell has discharged to zero and current is still drawn, the reverse voltage will be clamped at about 0.2V. This is probably enough to prevent any electro-chemistry taking place.
This site has a lot of good information Basic to Advanced Battery Information from Battery University
Old 2nd March 2013, 03:19 PM   #12
elboa8 is offline elboa8  France
Question CutOff
Originally Posted by scwhiteley View Post
Greetings,
Anybody have any suggestions for a battery over-discharge protection circuit?
I have been using home built NiMH battery packs in some of my projects. (for instance my most recent uses 10 C cells). However, after doing some research, I've learned that these packs (also LiPO) packs, can run into trouble if they become over discharged.
I think I'd like to learn how to incorporate a circuit design that would not allow itself to operate if the terminal voltage of the battery dropped below a certain point (for instance 10V for the 10 cell NiMH pack.)
I've done some searching around and have come across a few designs, just curious if you folks had some insight in the area.
My most recent project did incorporate a six LED battery meter using an LM3914 chip which I calibrated such that the last LED is lit when the battery is at 10V, so I know not to operate the gizmo beyond that point, but I'd like to develop an actual under-voltage lockout.
Thanks for any suggestions!
This may help. It's been in use for about 3 months.My design.
Old 2nd March 2013, 03:24 PM   #13
Default UnderVoltage cut off
Opps the pic got lost somewhere.
Old 3rd March 2013, 11:07 AM   #14
This the same protection that should be incorporated into every NiCad battery pack.
But rarely is !!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th March 2013, 04:08 AM   #15
Perhaps I should protect each cell with one of these diodes from digikey:
LX2400ILG Microsemi Analog Mixed Signal Group | LX2400ILG-ND | DigiKey
It appears to be a bypass diode for solar applications, the voltage drop is only 65 mV! And they only cost $14 a piece! Significantly more than the cost of each cell!... Just kidding. I think I will protect the pack with some cheap-o schottkys though.
I also intend to implement the under-voltage cutoff with the MOSFET approach... haven't 100% decided on the trigger yet. Going to do a little more research and hopefully get an order in to Digikey early this week so I can start testing.
Old 6th March 2013, 12:15 AM   #16
Originally Posted by Andrew Eckhardt View Post
Pretty much. The 431 has an internal 2.5V reference so tune a divider to hand that to the reference pin from whatever trip point voltage you want. Tie the source pin of the P channel enhancement FET to B+. May as well be a fairly large transistor to minimize loss. You're not looking to regulate or do anything very dynamic so bias isn't too critical. Maybe a 10K resistor from gate to source, TL431 cathode connected to the gate, anode to ground. FET drain to load. You might want to add a 15V zener clamp to protect the FET gate. If the supply voltage can go higher than that you'll need to be sure the TL431 doesn't try to drive big current into the clamp. 1k series resistance would be fine. See the TL431 datasheet. Figure 24 in the TI sheet shows a bipolar based shunt regulator, where if you swapped in a PFET and instead of grounding the drain used it to feed the load, you'd have the general idea.
If you are concerned about power consumption you can increase the bias resistor and use quite high resistances for the divider network, but I'm not sure what the limits would be without looking at it more closely.
Still piecing this one together Andrew. Just out of curiosity, why did you choose a PFET for this application? Does the TL431 deliver negative voltage to the PFET gate?
Old 6th March 2013, 01:41 AM   #17
I was initially thinking of a minimalist arrangement that the shunt regulator and PMOS would satisfy, but it turns out the IC doesn't have enough voltage gain to drive the FET directly, and by the time you satisfy all the other requirements it might be more complicated and not work quite as well as an opamp/ comparator arrangement.
Old 6th March 2013, 03:10 AM   #18
paulb is offline paulb  Canada
Check out Fig. 64 & 65 in
http://www.ti.com/lit/ds/symlink/lm10.pdf
Drive a FET instead of an LED? Low power.
Old 6th March 2013, 09:53 PM   #19
I think I was misunderstanding the use of the PMOS. I thought it needed a negative voltage on the gate. But now that I look into it more, it appears that the voltage just needs to be "more negative" than the source voltage?
Am I understanding this correctly?
It seems to me that I could probably use either a P or N channel MOSFET for my application. However, I have lots of parts and inputs and whatnot that connect to ground, so it seems the design might be a little less complex if I can maintain a common ground on the PCB and in the total design itself (i.e. the enclosure). To keep the ground common across all components, it seems that putting the MOSFET shut-off on the high-side is preferable, which means going with a P-channel MOSFET.
I've looked at a few datasheets for these on digikey. Interestingly, one datasheet gave the Vgs as a negative value (around -3 V I think). However the datasheet for the MOSFET I've ordered to test with:
http://www.onsemi.com/pub_link/Colla...MTP2P50E-D.PDF
Indicates a positive Vgs value, (about 3 V).
Am I correct that the Vgs of the P MOSFET needs to be negative in reference to Source? i.e., the voltage in my setup would be something like 12V to source, and 9 V (12-3) to the gate for ON operation?
Old 21st March 2013, 01:51 AM   #20
Jsixis is offline Jsixis  United States
digital relay 10 volt
Li-ion Battery Discharge Calculation teleman Power Supplies 6 17th January 2013 12:19 PM
Battery cut off circuit nightanole Power Supplies 12 28th December 2010 04:58 PM
Rail capacitor discharge circuit rtarbell Solid State 8 9th October 2006 11:51 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Protection circuit palesha Solid State 5 28th March 2002 06:13 AM
Copyright 1999-2017 diyAudio
