| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
Great response guys! Much appreciated.
Felipe, these were bought over 10 years ago from Percy Audio so possibly same stock as yours! Rob41, I haven't reformed them as I didn't think a Blackgate would have drifted this much. I'll give it a try though and report back. I can't say what vintage the "good" one is as it was purchased as used but I would agree with you that it seems odd to change the printing on the same value cap. Unless there is a large gap between production years? Kevinkr, I don't know definitively what the maximum tolerance should be, (appreciate I'm only -15% out) but I would have thought this grade of cap would be less than 10%. Larry Ng, Your tolerance measurements are what I would have expected, hence my suprise at what I got with mine. These have never been soldered/used, just kept in my parts box. They were shorted out before measuring on my Fluke 189 so the readings are accurate. I'll take some more photos in daylight tomorrow afternoon and check my other Blackgates for tolerance and printing layout. I had already measured 4 NOS non-polars, 330uf, 100v, which were 337uf 338uf 338uf and 340uf, a maximum of 3%. These have been stored with the suspect ones. The printing on these are different again! Confusing! If these weren't potentially so valuable, I'd cut them up. A bit drastic though if they are genuine. |
#22 |
Yes I sell second hand originals Black Gates bought to Michael Percy Audio USA, what's the problem if I can help someone asking if his caps are fakes or not.
#23 |
How hard can it be to just plug them into a circuit and listen? Good or bad, their sonic signature is unmistakeable.
Taking one apart is another option. It's kinda surprising there haven't been fakes around so far. |
#24 |
honestly, what were they originally other than fancy proto type caps, made with old outdated dry cap technology
I really expect the latest dry cap technology to be superiour the off values you experience is probably why further devellopment stopped, and so the production I guess they could buy the 'devellopment' caps and even get the 'audio labelled' with Black gate name, rather cheap but after it had been decided 'to go other ways' with dry cap production, it might have taken quite a bit bigger serious money to make them continue production and the end of that 'adventure' or the technology really had serious flaws |
#25 |
If you bought to Michael Percy you don't have to worry about: these are for sure originals. When I measured brand new without use always the cap measured less. These 330uF 100V dimensions are 18mm x 36mm?
#26 |
#27 | |
#28 | |
but you make a good point about trying them in circuit. I don't think I'll chop them up just yet though.Dean |
#29 |
Yeah, that's an expensive proposition.
Nikko Alpha 650/SAE 2600/SAE 2400/Soundcraftsmen MA5002/Heathkit AA-1800/Heathkit AA-1600 |
#30 | |
Dean |
| What is the substitute for blackgates? | AJ Bertelson | Parts | 1 | 25th March 2009 03:40 PM |
| Cerafine VS Blackgates? | Htguy | Digital Source | 5 | 24th January 2006 10:10 PM |
| Trade: opa637 (or something else for) Blackgates | wrath | Swap Meet | 2 | 31st December 2005 03:54 PM |
| Where can I buy Blackgates??? | K-amps | Parts | 3 | 25th February 2005 01:07 AM |
| Do Blackgates age? | ainami | Parts | 4 | 10th January 2005 10:34 AM |
