Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How to find if a LNB ( satelite dish ) is good and how to position .
Old 20th November 2003, 02:48 PM   #1
darkm4n is offline darkm4n  Romania
darkm4n's Avatar
Send a message via ICQ to darkm4n Send a message via MSN to darkm4n Send a message via Yahoo to darkm4n
Default How to find if a LNB ( satelite dish ) is good and how to position .
Hi ,
I just finish installing a second hand satellite antenna .
I have a Grundig 0.7 dB LNB and a 1.4 Meter reflector .
I put the antenna on the top of my house , it is not firmly fixed , it swing a little at wind but i will fix it more good in the next day .
I don't know how to find where to put the LNB and to see if the LNB is functinaly . I also have a Sat Plus receiver with OSD .
How i can find the correct angel and the correct position for the Astra sat ?
I put the antenna today like the other i saw at my neighbour houses , and not work ...
What i have to do ??
Thank's , Mihai.
Old 24th November 2003, 04:46 AM   #2
hifi is offline hifi  Sweden
If your aim is just slightly of at the ground you will miss the satellite by a huge margin in space therefore you have no chance of adjusting it properly from just watching your neighbours antenna.
Use a compas to set the right direction then adjust the height of the dish I think the old astra are 19,2E and the newer Sky is 28E?
If you have a satellite seeker it helps otherwise you can just put the reciever in scan mode or similar and place the tv so you can see the signal quality graph, from the roof and adjust acordingly ( a lot of shouting will be involved if you cant se the tv yourself).
/ micke - Who gets Astra Hobird Sirius and Thor at home -
How to find if a LNB ( satelite dish ) is good and how to position .Hide this!Advertise here!
satelite mtm system. oon_the_kid Multi-Way 16 17th January 2009 02:54 AM
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 09:02 AM
Can't find a good silkscreener antness Parts 8 27th July 2004 08:07 PM
Copyright ©1999-2017 diyAudio
