Help replacing Logitech Z-2300 transformer for US to UK move (120V to 230V) - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th February 2013, 11:37 AM   #1
Default Help replacing Logitech Z-2300 transformer for US to UK move (120V to 230V)
First post. I'm looking to get some help converting my Logitech Z-2300 from a US variety on 120VAC to work on the UK's 230VAC.
I found this post very informative:
Help required on Logitech Z-2300 toroidal transformer
However the OP there was looking to replace their transformer and eventually just got it repaired. There was some very useful discussion along the way.
I'm assuming if I can replace my 110V transformer with something that can match the original's output then I should be good to go. Is that assuming too much? What else would I need need to look at? Frequency will be different, will that affect capacitors? Other components?
So here's my train of thought on the replacement transformer:
Picture of my transformer attached.
US version:
Model: TOU433027F0
Input: AC 120V/60Hz (BLK-WHT)
Output: AC 19.9Vx2 (YEL-BLK-ORG)
The EU version is as follows:
Model: TOG433028F0
Input: AC 230V/50Hz
Output: AC 20.1V x 2
VA: 150.9
Again I'm assuming the ratings downstream of the transformer are within +/-10% between the US & UK versions, especially considering the outputs are within that tolerance. So if I can find a transformer that can match the EU transformer specs I should be good to go right?
Here's what I found:
An Airlink transformer:
Model: CM0160220
Input: AC 230V
Output: AC 20 x 2
VA: 160
Now here's a slight difference between the two: the Logitech transformer only has three leads coming out of the transformer so it seems to be a center tapped transformer. The one I've picked out is a dual wound transformer with four leads out. According to the linked post above that should be OK. I just have to tie the two ground lines together and connect them where the center tap in the Logitech setup would go. Correct?
Any confirmation, correction would be greatly appreciated.
Old 9th February 2013, 01:51 PM   #2
DUG is online now DUG  Canada
"I just have to tie the two ground lines together and connect them where the center tap in the Logitech setup would go. Correct?"
Yes, but measure to make sure the phasing is correct...you will either get 40VAC or 0VAC across the two "outside" lines...You want 40VAC.
Make sure your transformer of choice runs at 50 Hz.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Help required on Logitech Z-2300 toroidal transformer RishiGuru Parts 42 18th January 2017 01:17 PM
Using 230v Transformer with 120v Mains Phostenix Power Supplies 3 24th September 2009 08:46 PM
Help! Logitech z-2300 ckim8 Multi-Way 0 27th December 2008 09:20 PM
500W ILP UK Toroidal Transformer 115/230V OK (Canada) happycat Swap Meet 0 6th April 2007 06:11 AM
Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers Eva Swap Meet 1 28th July 2005 03:00 PM
Copyright 1999-2017 diyAudio
