Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Recommendations for IEC plug
Old 9th February 2013, 10:53 PM   #11
Speedskater is offline Speedskater  United States
Speedskater's Avatar
One day I measured some of the spare power cords that I had on hand. Using a very nice 4 terminal Ohm meter. Some of the cords had end to end resistance of about what I expected. Some were a litter higher, but still OK for low power units. A few were way higher and only suitable for the trash can.
Kevin
Old 10th February 2013, 08:49 AM   #12
ginetto61 is offline ginetto61  Italy
Originally Posted by xjr100 View Post
I have both cables - DH-Labs RedWave and PowerPlus. PowerPlus is without shield and RedWave is shielded.
I've tried PowerPlus with digital source: it really gives something in sound.
Something nice ? you mean you prefer the unshielded one with the digital source ?
It wokrs like mains filter - I've measured +5V power output on Dune HD Base 3.0 media player with scope.
There was some noise canceling with PowerPlus.
If I understand well the shielded one let through more of the noise coming from the electrical grid. Very interesting.
But I would like to explain why I have become a little obsessed with this contact efficiency in plugs
I had a cheap cord in one of my old amp with a very bad two terminal plug
as an experiment I replace it with this one
and I really felt some improvements like less noise and more power for a same position of the volume knob with same discs.
I am a believer of the quality of connectors. Or better of the contact.
Just cleaning with some solvent the rcas usually gives amazing results.
I opened some of the above depicted IEC female plugs
The quality is very varying
But I cannot say nothing about the quality of the molded ones of course.
But I would think that some kind of difference exists and influences the overall sound.
For instance the copper tends to oxidize. The rodhium not but it is very very expensive. But I like it very very much.
gino
gino
Old 11th February 2013, 10:24 PM   #13
Enzo is offline Enzo  United States
I live in the world of guitar cords, and I like to think there is a lot of difference between a cheap $4 molded plastic guitar cord and a good quality $30 guitar cord. Obvious quaility difference in performance. Where they lose me is between the $30 and the $150 cord.
Old 12th February 2013, 07:26 PM   #14
Hi ! I became aware of the importance of a good contact quality when I cleaned some rcas with a solvent for dry cleaning
Bad smell aside I was literally floored by the difference in the sound
Much cleaner ... of course
Joke aside the improvement was very remarkable
And the cotton that I used for the cleaning became black for the dirt
So dirt is one issue
Another issue is the mechanical matching between contacts
For instance i do not understand why a superior connector like the bnc has not replaced the rcas
And the perversion is reached with digital where the used rcas for the spdif output while in all other sectors they use bnc.
I think that audio has something to learn from professional video for instance
The bit rate of a HD video transmission is so much higher than audio digital transmission that a superior quality connector is mandatory
And analogue signal are even less critical
I am pretty sure that a low quality bnc is better than a high end rca
But in this way being the rca a inferior connector by design they can sell top quality rcas at 50 USD/each when a 0.5 USD bnc would be perfect.
That is the audio way I suppose
Sorry for the outburst
Thanks and regards,
gino
Old 2nd December 2013, 05:17 PM   #15
c3474 is offline c3474  United States
I know this is an old post, but..
Enzo. I like your practical approach to "shielded" power cable. I think in 85% cases your advice is valuable, however one particular scenario may have been overlooked. As you know, die hard audiophiles get pretty nuts sometimes. Some people grow distain for the unshielded power grid (as you have described) and add power filters such as a furman or even a power regenerator. I think in this case - and this case only - a shielded power cable could be valuable. It ensures that the ac signal is minimally affected by EMI/RFI while traveling from the filter/regen to the component like a power amp or DAC.
Originally Posted by Enzo View Post
It depends on if you are looking for good quality relaible power connections or if you are looking for some special audiophile qualities. There are people who will spend $250 for a cord liike that, then the rest of us find nothing wrong with a generic cord.
Shielding? What do you want to shield from what? Shielded power cords in computer and other digital equipment is more about preventing noise from radiating OUT from the cord. COnsider that noise in your local environment is many magnitudes smaller than the 120v or 240v of your mains. Not only that, but the impedance of your mains wiring is not very sensitive to picking up fields unless your power cord runs through an MRI machine on its way by.
If you mains wiring is anything like mine, it starts at a step down transformer on a power pole near my home. From there, unshielded wires run from pole to my house, through my electric service panel, then through the unshielded wires in my house walls. Just my opinion, but i am not sure what shielding the last few feet of all that would do for me.
If you feel better with industrial style connectors, whenever they come from audiophile sources they cost a lot more than they should. If you have electricians in your area wiring houses and such work, then you have electrical supply companies there too, selling the electricians their parts. You can find good and premium quality connectors at places like that. No audiophile markup and no shipping cost. Look into "Hospital Grade" connectors and power cords if you are interested. They may call it something else in Norway, but such power connectors have "better" specs on reliability and strength of connection. It isn't so much about electrical qualities as it is things like how easy it is to pull it out of the outlet or how likely it is the hot parts can be exposed
http://www.ul.com/global/documents/o...eceptacles.pdf
Recommendations for IEC plugHide this!Advertise here!
240/300 Ohms balanced IEC FM-Plug for flat Dipole Wire and for Disass'y e. g.Quad FM3 tiefbassuebertr Analogue Source 13 4th July 2014 08:56 PM
Suggestion for plug-in enhancement or new plug-in Brisso57 miniDSP 1 8th November 2010 05:59 AM
chip burn-out when plug-in or plug-out DVD signal lines xujing79 Class D 3 3rd August 2010 05:07 AM
Where to get IEC Chassis Plug? ervington Parts 12 4th October 2006 03:14 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
