Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Binding posts Brass vs Copper : does really makes differences ?
Old 31st January 2013, 04:02 PM   #111
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by SY View Post
Three things matter here:
1. Connection quality.
2. Connection quality.
3. Connection quality.
Why is that so difficult to understand?
If limiting to three, defining "quality" is helpful:
1. Initial electrical resistance of the connection, ideally being as close to zero ohms impedance as possible.
2. Resistance of the mating surfaces to corrosion, which can eventually increase impedance to infinity or create an impedance curve that affects frequency and dynamic range variations.
3. Resistance of the mating surfaces to physical deformation, deformation can also increase electrical impedance to a point of audible detection.
Point # 3 is often a problem for DIY types who tend to use the connections often, while #2 is the greater problem for static situations, especially in salt air environments.
The problem with #1 is "connection quality" is almost always good for most connectors initially, it's what happens down the road that separates the wheat from the chaff.
Old 31st January 2013, 04:10 PM   #112
On Hiatus
SY's Avatar
Precisely why I made the point in more detail earlier on in this thread. The focus on irrelevancies like diameter diverts attention from exactly those issues.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st January 2013, 04:16 PM   #113
speaker dave is offline speaker dave  United States
speaker dave's Avatar
One comment on the "Dynaco" type screw terminals mentioned a few pages back. I now work for a company that does a lot of professional installations. These are for audio, video, and contact closure/power supply to external effects. Reliability is crucial and most of the connections are screw connections of some kind. the Old Dynaco/McIntosh etc. barrier strips are still used. However it is crucial to use them with matching spade connectors. Bare or stranded wires were an invitation to shorts and every amplifier manual in the 50s/60s had pretty diagrams about the evils of wires touching.
The only problem is that the wires then get crimped into spade connectors and the reliability problem migrates upstream (personally I would solder them into the spade connector. Too often a wire can be yanked out of a crimped spade connector). Still, the industry considers this a reliable connection.
The other half of our gear uses wires screwed into Phoenix connectors of various types. This is seldom bare wires, more frequently it is with crimped on pins that are screwed into the terminals. This gives a cleaner installation and less chance of shorting between wires.
David S.
Old 31st January 2013, 04:19 PM   #114
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
There is crimping and there is crimping.
A proper crimped joint is considered a cold weld and is superior to soldering.
A poor crimped joint is just wires squashed into a connector - that is a difefrent matter altogether.
Old 31st January 2013, 04:30 PM   #115
bear is offline bear
expert in tautology
bear's Avatar
One problem with a "proper" crimped joint is that if there is sufficient pressure applied to make a good oxygen free joint, one also risks imbrittlement (work hardening) of the local area which may cause stress cracks and breakage. Thus, solder.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 31st January 2013, 05:26 PM   #116
a.wayne is offline a.wayne  United States
Sin Bin
With the "right tool" crimping is best ......
Old 31st January 2013, 05:46 PM   #117
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Crimping is ok. I use Cembre crimps at work, and they arent half bad. However, the addition of soldering is almost necessary in circumstances. Pros dont bother, probably because given 5 years in a damp or salty atmosphere they degrade and need replacing. The only crimps Id consider a cold weld are the hydraulically applied types which are from 70 sqmm upwards. In those sizes the wire will break before it can slip. Speakon and XLR are great, until the contacts get dirty, and require regular cleaning. Not a problem with multi kW pro sound, but more of an issue with HE speakers and flea watt amps id suspect. Most are rated at 5mOhm contact R, clean bare wire or crimps, and binding posts are significantly better. I use binding posts for a resistance bridge measuring 20mOhms range. Joint R is a fraction of an mOhm. My 2 pence.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 31st January 2013, 06:01 PM   #118
qusp is offline qusp  Australia
qusp's Avatar
They're changed from time to time. This one is from a rather controversial fellow named John Derbyshire.
Eddy currents?
yeah I know, I usually dig them, but this one stood out and I wanted to know. thanks for the tip i'll look him up.
ive gone in a different direction with the current build.
i'm using Lemos for signal, 4 way speakons and ITT 8 way Cannon Bayonette MIL on the next multiway rear panel. easy, very secure and with hermetically sealed solder and mating connections. anything else gets pretty stoopid on multiway, multi-amped speakers and amps. i'll double up on the bass so 2 x 16awg pins per phase, then 1 each phase for the mids and highs
hard silver plate, but I dont expect them to degrade to quickly with no oxygen. the model # on the panel mount is CA3102E20-7P-B
Old 31st January 2013, 06:04 PM   #119
Sin Bin
I do solder if not crimped with the correct tool, when doing FAA harness's crimping is what is allowed, you need the right tool and connector, when crimped correctly much better than any solder joint ..
No heat also means no compromise to the insulator ....
http://aeroelectric.com/articles/terminal.pdf
Old 31st January 2013, 06:12 PM   #120
qusp's Avatar
yeah if I had the choice I would have chosen crimped for the Cannons, but I got the panel mounts and connectors on the FS area here for a song (pretty awesome if you know what these connectors are worth) and the crimping tools for them run to several hundred dollars.
Binding posts Brass vs Copper : does really makes differences ?Hide this!Advertise here!
FS: Conrad heatsinks, cardas copper binding posts, more to come... milezone Swap Meet 2 6th December 2012 08:09 PM
soldering binding posts and copper litz wire FrankDIY Everything Else 14 17th December 2009 06:12 PM
FS: Eichmann Cablepod copper binding posts ungie Swap Meet 2 15th May 2009 02:28 PM
12 solid copper speaker binding posts karma Swap Meet 3 30th September 2005 03:30 AM
Copper Binding Posts siu sin man tho Tubes / Valves 0 5th April 2003 03:05 PM
Copyright ©1999-2017 diyAudio
