Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st January 2013, 01:33 PM   #101
diypass is offline diypass  Italy
...is better a big conductor with poor current proprieties or slim condutor with axcellent current proprieties ???
Old 31st January 2013, 01:34 PM   #102
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by diypass View Post
if would suggest me no compromise binding posts
What is "no compromise"? I just look for posts that are well made and where it's easy to get a good connection. Cardas, WBT, Dayton Audio, whatever. It's the mechanics of the connection that concern me most.
Take the Speaker Voltage Test!
Old 31st January 2013, 01:39 PM   #103
simply transparent to signal path.
Old 31st January 2013, 01:43 PM   #104
expert in tautology
bear's Avatar
Bear, I don't think you are reading SY's posts very well, or you're reading something into them that I don't see.
SY said that it was imagination to find any difference between brands - in response to a post that asked that.
I'd say there are differences in some cases.
It's a crap shoot to a great extent.
Most are essentially "blameless" - some seem to have odd effects. So percentage-wise almost any will be ok.
However the implication, of SY's statements in this thread is that all of the metals used for audio connectors and wires sound the same. I can not agree with that at all. They simply do not all sound the same.
In most cases the differences are more subtle than the sound you might be able to detect listening to a car stereo or from a decent hi-fi set up. But in a very well set up and clean system, I find that there is no ambiguity at all in the effects of things like Rhodium and Copper and Silver. Of course if you use various things in various places, you spread the effects around and homogenize it all. Maybe that is not a bad way to go...
...in fact I find it down right disconcerting to hear this happen at all. Things would be much simpler and easier if it *did not happen*! It's confounding.
Are there more significant and important things to get right in a system first? You bet. Work on that first. Worry about metals and connectors later...
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 31st January 2013, 01:58 PM   #105
expert in tautology
bear's Avatar
Why don't you share with us what your system consists of, or what you are building/modifying that will use these binding posts?
Fact of the matter is that everything in audio is a compromise.
Imo, one will need a "world class" tweeter, hearing to match, and almost perfect signal path start to finish before one need be concerned about what are extremely subtle factors like which binding post to use.
Chances are it will make no difference.
_-_-bear
Old 31st January 2013, 02:06 PM   #106
Pano's Avatar
You are worrying about the wrong things. See Bear's post above.
Old 31st January 2013, 02:36 PM   #107
SY's Avatar
Three things matter here:
1. Connection quality.
2. Connection quality.
3. Connection quality.
Why is that so difficult to understand?
If there's a sucker born every minute, where do the rest of them come from?
Old 31st January 2013, 02:44 PM   #108
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
SY, where is your tag line from?
Old 31st January 2013, 02:46 PM   #109
nicoch58's Avatar
SY , eddy current ? (amp side)
Sic58
Old 31st January 2013, 02:58 PM   #110
SY's Avatar
They're changed from time to time. This one is from a rather controversial fellow named John Derbyshire.
Eddy currents?
FS: Conrad heatsinks, cardas copper binding posts, more to come... milezone Swap Meet 2 6th December 2012 07:09 PM
soldering binding posts and copper litz wire FrankDIY Everything Else 14 17th December 2009 05:12 PM
FS: Eichmann Cablepod copper binding posts ungie Swap Meet 2 15th May 2009 01:28 PM
12 solid copper speaker binding posts karma Swap Meet 3 30th September 2005 02:30 AM
Copper Binding Posts siu sin man tho Tubes / Valves 0 5th April 2003 02:05 PM
Copyright ©1999-2013 diyAudio
