Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Use relays to control input channels
Old 23rd January 2013, 03:39 PM   #1
hansibull is offline hansibull  Norway
hansibull's Avatar
Default Use relays to control input channels
hi!
I'm making a gainclone, which only have one input source. I'm thinking about controlling the amplifier with an Arduino (a microcontroller), that can control the heatsink temp, turn fan on or off if necessary. I will also make it compatible with IR remotes. But yes, back to the question. I'm going to make four diffrent audio inputs. one for cd, one for AUX, one for LP and one for Radio. can i use relays for controlling inputs, like my fancy little schematic shows? Will this affect the music quality?
LINK TO RELAYS:
New 5V 8 Channel Relay Module Board for Arduino Pic AVR MCU DSP Arm Electronic | eBay
Old 23rd January 2013, 03:51 PM   #2
palmas is offline palmas  Portugal
You can and probably it is the best way to do it, considering you're using a good type of relais
Use relays to control input channelsHide this!Advertise here!
Need help: Input selector control for 6 channels diarav Analog Line Level 7 29th November 2012 08:23 AM
Capacitor on the DCX2496 relays control Mambo Digital Line Level 2 27th April 2009 01:28 PM
Reed relays in passive volume control? hermanv Analog Line Level 24 4th May 2008 04:50 PM
how to control 6 channels using one pot Tambourine Man Chip Amps 26 16th November 2007 06:07 PM
Relays for Aleph P1.7 volume control xenofex Pass Labs 0 28th April 2006 04:32 PM
Copyright ©1999-2017 diyAudio
