| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Greetings, I am looking for some suggestions on a low noise 12VDC regulator system that can accept 9V to 16V input, and permit 8A continuous current flow. Most that I've seen that offered low noise operation in the 10μV range appear to be limited to about 2.5A. The regulator could use multiple devices, and can be case-mounted to provide cooling or have its own heatsink. Thank you in advance for all suggestions.
| Suggestions on PCB: LM317 As Walwart Regulator (1st Eagle PCB) | tommy_o | Power Supplies | 10 | 14th July 2011 03:05 PM |
| Suggestions for voltage regulator | uzernaam | Solid State | 4 | 27th October 2010 12:27 AM |
| Looking for the ideal linear SMD voltage regulator, any suggestions? | rhysh | Power Supplies | 2 | 12th March 2009 02:07 AM |
| Suggestions for a high-power low noise Zener regulator ? | youyoung21147 | Power Supplies | 0 | 29th November 2005 11:48 AM |
| Need suggestions on tube regulator. | contaxchen | Tubes / Valves | 5 | 30th January 2004 10:02 PM |
