Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What's a fuseable resistor?
Old 17th January 2013, 01:16 PM   #1
maylar is offline maylar  United States
Default What's a fuseable resistor?
A friend of mine needs to replace a resistor in his printer (not audio, sorry) that's listed as a "fuseable" resistor. In the fuse module there are 2 resistors, a 100K maybe 1/4 watt and this fuseable 56 ohm thing that looks to be a standard metal film part:
I can't find anything in Mouser or DigiKey that references fuseable resistors, so I'm wondering what's special about it and what's the best replacement item. He says the part is open circuit, so obviously it does act as a "fuse".
Thing is, I've seen metal film resistors catch fire when overloaded so I'm really at a loss here.
dave
Old 17th January 2013, 01:34 PM   #2
madtecchy is offline madtecchy  England
It is not a metal film resistor. Most common place i found these fuseable or saftey resistors was within CRT Televisions ... Used to buy mine from a place called wiltsgrove electronics in birmingham
Old 17th January 2013, 01:35 PM   #3
oz7aff is offline oz7aff  Denmark
oz7aff's Avatar
Fusible resistors is exactly what the name says, a resistor that act as a fuse. They was very often used in tube type monitors, in the high voltage supply.
You should be able to find them searcing for fusible resistor og fuseable resistor.
Regards Max
Old 17th January 2013, 01:38 PM   #4
They can be found here Electronic Components | Electronic Parts | Farnell United Kingdom
Old 17th January 2013, 02:16 PM   #5
Enzo is offline Enzo  United States
I'd take the advice oz7aff gave - do your search for "fusible" resistors. I just plugged that into Mouser and it came back with a bunch. A place to start anyway.
Old 17th January 2013, 08:15 PM   #6
Thanks a bunch. Silly me.. a spelling error.
dave
Old 17th January 2013, 08:51 PM   #7
R.I.P.
I'd say its a part guaranteed to go open circuit if overloaded, and
guaranteed to able to interrupt certain voltages and currents.
I'd guess its possible melting resistors could go lower in value
and short, rather than go open, but I've never seen it, all
fried resistors I've come across have been open circuit.
Perhaps an extra section that melts at a given power.
rgds, sreten.
What's a fuseable resistor?Hide this!Advertise here!
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
resistor help Mass Car Audio Class D 2 26th December 2008 04:33 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
What is this resistor ??? Lyra Digital Source 8 23rd January 2004 10:18 AM
Gain Clone Entry Module? Corcom fuseable with switch. KevinLee Swap Meet 0 24th April 2003 02:34 AM
