Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th November 2003, 01:00 AM   #1
cocolino's Avatar
Question Help! Search for BA715 IC OP-Amp(?) datasheet
Anybody who has infos or even a full datasheet for this IC??
I searched google now for about an hour and all I came up with is that it seems to be a dual opamp. and ROHM (never heard this) is supposed to be the (or one of) manufacturer.
Any further kind of info regarding this part is highly appreciated!
It`s in a strange (to me) 9 pin plastic case that is called SIL-09 (or SIL-9) and looks like this:
Christoph
STEAL the BEST - INVENT the REST
Old 16th November 2003, 08:14 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Depending on what you need from the sheet, the NJM4558 comes close.
http://212.57.231.17/datasheets/71/KUTVSUNPVQ.pdf
If this doesn't work try this:
http://www.dialelec.com/605.html
Here's a better and slightly more complete copy:
http://www.hoohahrecords.com/resfreq...ts/njm4558.pdf
/Hugo
Old 16th November 2003, 09:26 AM   #3
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Re:
Pin-out: (SIL-9):
Arne K
Ars longa, vita brevis
Old 16th November 2003, 09:27 AM   #4
DIY !
Cobra2's Avatar
Cheap & easy replacement; find the quad version of your favourite, straighten the leads, cut off the surplus!
Arne K
Old 16th November 2003, 09:39 AM   #5
diyAudio Moderator Emeritus
jean-paul's Avatar
Clever solution !
It's only audio
Old 16th November 2003, 12:44 PM   #6
cocolino's Avatar
Thanks very much guys for Your all Your efforts!!
Well, then that`s an "ordinary" dual op-amp. as ordinary it can be. Good to know - I thought it maybe is something special.
Also I don`t need to replace (at least I think so) one of these BA715 (I just want to figure how the circuit works respectively what it is at all) IŽll keep this solution in mind - indeed very clever - and simple too! Thanks Arne!
Christoph
Page generated in 0.07925 seconds (73.96% PHP - 26.04% MySQL) with 11 queries
