diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   2SK170BL Vp (http://www.diyaudio.com/forums/parts/227889-2sk170bl-vp.html)
RCruz 15th January 2013 05:34 PM
2SK170BL Vp
After building a rig to measure 2SK170BL Idss and Vp, I am slightly puzzled by the measured results.
The rig consists on a 100 oh resistor in series with the Gate and Source pins (shorted together), where I measre Idss using a 9v bat over the fet.
The Vp rig uses a 1M ohm resistor for Rs and the gate to gnd.
The values I got are:
Idss Vp
6,32 -0,58
6,33 -0,57
6,55 -0,58
7,33 -0,63
7,47 -0,62
7,98 -0,66
8,14 -0,64
8,28 -0,64
9,16 -0,69
10,04 -0,71
10,39 -0,73
Looking at the K170 datasheet, I was convinced that for a 8mA Idss, I would get Vp near -0.45V and not -0.64V as per my measurements.
I am writing this hoping to get some input from other experienced people that might helpme understand this issue.
Ricardo
merlin el mago 15th January 2013 05:40 PM
Ricardo to be sure I will use a bench psu instead the battery.
Cheers
Felipe
RCruz 15th January 2013 07:54 PM
Yes, but the results are very consistent.
I want to use the actual Vp for the k170 to build a common source jfet amp calculator :)
stinius 15th January 2013 08:50 PM
1 Attachment(s)
Originally Posted by RCruz (http://www.diyaudio.com/forums/parts/227889-2sk170bl-vp.html#post3327278)
Ricardo
Are you sure?
RCruz 16th January 2013 07:17 AM
Thank you stinius.... I was not looking at the correct graph.
So I can assume the relation between Vp nd Idss is fairly linear.... I will do a regression with my data and ee if I can duplicate that plot. :)
RCruz 16th January 2013 07:40 AM
1 Attachment(s)
Here it is
RCruz 21st January 2013 05:50 PM
1 Attachment(s)
And finally the calculator.....
Please take it with a grain of salt regarding Gain calculations.
Hoping for good comments.
bear 21st January 2013 08:32 PM
The assumption that you have a genuine Toshiba part, may or may not be valid.
Copyright 1999-2017 diyAudio
